mark, aluminum gears...
Old May 29, 2002 | 10:30 AM
jim henderson's Avatar
jim henderson
Old Jun 4, 2002 | 01:21 AM
V10man's Avatar
V10man
Mark, I saw a post somewhere where you were discussing the gears in a E4OD/4R100. Someone was saying his gears were aluminum. At any rate, I found this site which shows the yrs and pics of the gears for the trannys. Thought you might be interested. Good info. http://www.brianstruckshop.com/gears.html
Old Jun 4, 2002 | 07:16 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Thanks for the link!
Those are the gears in question. They are all steel.
The carriers, which is the part holding the gears in place, were either aluminum or steel. The gears themselves have always been steel.
Mark
Old Jun 4, 2002 | 07:41 AM
texan_eagle_scout's Avatar
texan_eagle_scout
I agree alum gears would shred under a shock or load. At that point your tires might not be the weakest point in the towing equation, it would be the foil confetti your gears just turned into when you try to pull a load.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
