3" rear blocks
Old Jul 7, 2016 | 05:36 AM
  #46
awq134's Avatar
awq134
I was able to order the Autospring complete 2" lift kit about 2 weeks ago. I finally got the time to install everything yesterday. The install was pretty straight forward, witht he exception that I was missing a required socket. The directions has you remove the forward bolt on the lower control arm to make room for the longer strut during the reinstallation. I thought I had a 21mm socket, but apparently did not. I was able to get around this step by removing the axle nut which allowed the lower control arm to droop even further allowing me to slide the lower shock mount into position. Other than having to figure that out and fighting rusted fasteners everything went smoothly.
I'm quite happy with the results. I started out at 37" up front and 39 1/4" out back. after the install I ended up with 39 1/2" up front and 41 1/4" out back.
Before
After
Old Jul 8, 2016 | 04:53 PM
  #47
D8chumley's Avatar
D8chumley
Resident smarta$$
Lookin good brother 👍🏼
Old Jul 8, 2016 | 07:10 PM
  #48
awq134's Avatar
awq134
thanks... I will admit though, with a little extra room between my tires and the fenders I noticed a lot of surface rust. It was either that or my new upper control arm on the passengers side with it's shiny new paint. Either way I pucked up some satin black enamel paint and touched up a few areas. What a world of difference a rattle can can make!
StickNString2
Jan 21, 2014 10:40 AM
bleedford
2009 - 2014 F150
Jun 13, 2011 04:17 AM
AndeyHall
Sep 19, 2010 04:20 PM
SMiller
Nov 15, 2004 10:51 PM
bigmack
13
Jun 30, 2004 06:11 AM
