Your engine was designed and built to handle that range of boost...
Ford is famous for design / implementation flaws with things like cylinder sealing.
Headgaskets / headbolts spec'd insufficiently was a HUGE flaw in the Windsor 302 as well as the 6.0 / 6.4 diesels.
One thing about that engine that blew Cory - if the crank journal for that cylinder is blue or black, odds are that it spun a bearing which then caused the piston to fracture if/when the bearing shells "stacked" and allowed the piston to hit the head or crank throws.. Pistons often get a bad rap because they are more fragile than the rods and pins..
Head bolts are just fine on a 302. Detonation will waste a head gasket far before head bolt failure will.
I'm sure you are well aware that the 6.0 and 6.4 were not designed by Ford but rather Navistar
Funny how a 9:1 engine can mildy detonate because of a slow EGR valve and blow the head gaskets... Ford F'd up big time by specing the 7/16" headbolts for the 302 since they only had 4 around each cylinder.
Making matter worse, Ford removed so much material from the deck of the 302 that you take a big chance with hosing up the block by installing the 1/2" bolts that it should have come with from the beginning..
Also As I recall - the Navistar group placed the blame on Ford for allowing boost to come on too fast and too high. Again - exceeding the design spec of the engines.
