4r75e question
Old Feb 23, 2016 | 07:28 AM
Oldsman003's Avatar
Oldsman003
Exclamation 4r75e question
Can a 4x4 trans be used in a 2wd application? If so what needs to be changed if anything.
Thank you
Old Feb 23, 2016 | 09:10 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes it can. The output shaft and extension housing need to be changed.
The extension housing just bolts on. The output shaft requires a complete disassembly of the trans to change.
Old Feb 23, 2016 | 11:02 AM
Oldsman003's Avatar
Oldsman003
So it's not just a simple change over of the tail shaft is it
Old Feb 23, 2016 | 03:24 PM
Mark Kovalsky
It's not a simple change. EVERYTHING comes out of the trans. The last part out is the output shaft. Put the new output shaft in, and then rebuild the trans.
Old Mar 22, 2016 | 12:21 PM
RODBURNS's Avatar
RODBURNS
Smile 4r75e fluid direction to cooler
which way is the fluid to radiator flowing, and where is the best place to tie in a new external cooler
thunderbolt427
Nov 6, 2012 06:31 PM
USMC0351fordtruckin
Apr 2, 2011 06:18 AM
wildbill74
Jan 25, 2010 10:23 AM
bfbiker
Mar 7, 2009 03:14 PM
enduringexplorer
Mar 21, 2005 12:40 PM
