transmission question
Old Jan 25, 2010 | 09:42 AM
wildbill74's Avatar
wildbill74
can u change the shaft out of a disel transmission to make it work for a gas motor
Old Jan 25, 2010 | 09:49 AM
ri_truck_guy's Avatar
ri_truck_guy
What kind of transmission?
Old Jan 25, 2010 | 09:57 AM
wildbill74's Avatar
wildbill74
It is a 86 ford f250 had a 6.9L disel the moter was toast so it is gone i am wanting to put a 351 in it it has a 4 speed trans and it is a 4x4. not sure what the transmision make is i just know the shaft is to big to work without changing it or putting a whole nother trans in it.
Old Jan 25, 2010 | 10:09 AM
bghnkinf250's Avatar
bghnkinf250
If you are talking four speed manual - all you have to do is change the bell housing. The shaft is the same.
Old Jan 25, 2010 | 10:15 AM
ri_truck_guy
The 4 speeds should swap, but I'm pretty sure the gear ratios are different between diesel and gas units. That makes sense as the gas units rev higher than the diesels. You should find a taller gear set in the diesel unit. You'll need the bell housing and clutch setup from the 351 also.
Old Jan 25, 2010 | 10:17 AM
wildbill74's Avatar
wildbill74
yea it is a 4 speed manual
Old Jan 25, 2010 | 10:23 AM
Franklin2's Avatar
Franklin2
Have you entertained the idea of getting another diesel engine and installing it? If you get yuorself up to speed on how they work, I think you will like it.
