Ok 85 motor and trans are on the deck next to the90 motor and trans to swap stuff over to the 90
On the 90 trans it has the 11/14 tail shaft and the 85 has 10 1/2 or 1/4 (brain drain) how easy is it to change the tail shaft and houesing over,can it been done with tearing tranys apart or should I just have the drive line redone to fit it
all so how to I upload a pic on here
thanks people
Phil
AOD, correct? Since some of the problems with earlier boxes was lubrication, I would be reluctant to swap any parts that might have anything to do with oiling inside.... Not a trans man, so I can't say for sure what parts were changed.
Chart seems to indicate only diff in length should be the main case:
thanks people
Phil
Oh Mr Mark will you weigh in on this can I just change the houseing or is it both shaft andd houseing or just do the drive line
Thanks again
Phil
I don't know. I don't know that much about this stuff. My expertise is in how the trans functions, not how the parts go together.
My guess is that you will need to change the housing and the output shaft. Changing the output shaft involves a complete teardown of the trans. It's the last part out of the trans and the first part in during the rebuild.
Ok can anyone else weigh in on this the cost of cutting the dr shaft is petty high so does any one know what rigs have the shorter front shaft for the truck
some one said something about still beable to use he same one cause the trany is only 3/4 in longer than the old one
i cant ck it cause its still out of the truck and I want to have it right before I put motor and trans back in the truck
Thanks Phil and thanks Mark for trying
