Help.. Run around with starters.
Old Feb 25, 2016 | 08:32 PM
  #46
dn29626's Avatar
dn29626
Originally Posted by entropyjones
Where would I get the extra bolt? Does it come with the starter? Where did you get yours?
I use the two bolts that came on the truck. Forget the third bolt.
Two bolts held the original starter. Two bolts will hold the replacement starter.
You can try my last suggestion with the starter you have now.
Old Feb 25, 2016 | 08:39 PM
  #47
dn29626's Avatar
dn29626
Originally Posted by BigRed1Ton
... # 35154, is that the starter for the 6.0L ? I know some guys prefer that one over the stock part for the 7.3L. Is this one a high-torque unit, is that why you changed over...
35154 is listed on the Oreilly web site for a 2001 F350 7.3
I went with it because it is new, not rebuilt and the core charge is only $10.
I paid the core charge and kept my original starter. My original has since been rebuilt and is ready to go back on the truck when the 35154 fails and is ready to be exchanged or rebuilt.
Old Feb 26, 2016 | 06:49 AM
  #48
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I agree that the "Denso" I posted above is a knock-off, but after comparing the images between the 35154 and the knock-off Denso, I would still go with the knock-off. It looks much more built/robust. Of course, if you wanted to do it right, get the real Denso and be done with it.
Alternatively you could go with the DB Electrical version, but you are still looking at knock-off starters at that point. At least it has the post on the side which may eliminate your need for modifying the lug.
Amazon.com: DB Electrical SND0355 Starter (d 7.3 Diesel Powerstroke Truck 1994-2003): Automotive Amazon.com: DB Electrical SND0355 Starter (d 7.3 Diesel Powerstroke Truck 1994-2003): Automotive
Old Feb 26, 2016 | 06:56 AM
  #49
BigRed1Ton's Avatar
BigRed1Ton
Quality starters
True. If you look carefully, EBay has an OEM Mitsubishi starter for $200, and a Bosch unit for $220. I believe the 7.3 came with either the Nippondenso or the Mitsubishi model, but I could be wrong. I would trust the Bosch unit to be good quality as they have a good reputation for electrical parts. IMO the rest are junk, and won't last very long, based on the stories I hear from 7.3 owners.
westroud
Jun 3, 2012 02:53 PM
savag
Feb 19, 2011 03:11 PM
sooline1
Oct 31, 2006 05:25 PM
Ryokotsusai
Oct 13, 2006 11:47 PM
fordloverf2501970
Sep 8, 2004 11:41 PM
