Sponsored by: Real Truck
TOW/HAUL PROBLEM
Old Jan 27, 2016 | 09:37 PM
9218xz's Avatar
9218xz
TOW/HAUL PROBLEM
does anyone have a diagram of where the transmission temp sensor is found .....i have a 2005 f 250 5.4l FX4....my tow haul light keeps flashing
Old Jan 27, 2016 | 11:15 PM
nojoke327's Avatar
nojoke327
Is it throwing a code for the temp sensor
Old Jan 28, 2016 | 06:46 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is on the solenoid body inside the pan.
Old Jan 28, 2016 | 07:31 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
See attached for TFT sensor location and R&R steps:
Old Jan 28, 2016 | 07:52 AM
9218xz's Avatar
9218xz
thx for the help.....hope i can be of help when you guys need it....thx again
Old Jun 10, 2024 | 12:06 PM
Intelectrix's Avatar
Intelectrix
1st Gear
Circuitry compromised
Did you happen to change your high mount brake light to an LED unit? Many circuits, especially older ones, cannot handle the inrush surges of LED lights. If a high heat resistor isn't incorporated into the LED unit to compensate for heat dissipation, damage to the circuit may result. It took out my brake switch twice before I figured it out. We can't pass smog with anything lit on the dash. Not even the turn signals! Good luck, and good truck!!
usmarine1979
Aug 15, 2016 01:31 AM
NoSlak
Aug 25, 2011 12:22 AM
Nathan
Dec 2, 2010 04:53 PM
autoxsteve
Aug 9, 2007 07:31 AM
MILL
Apr 5, 2007 11:30 AM
