P0713 code and assoc indicators - help
Old Aug 6, 2007 | 10:41 AM
autoxsteve's Avatar
autoxsteve
My problem is with our 2003 F250SD crew cab with a 6.0L powerstroke and a torqshift transmission. the problem occurs after the vehicle is driven a little. The trans temp rises to just about normal operating temp (less than 1/2 way) and then pegs.
I have diagnosed a fault (check gage/engine lights)the fault to P0713* "Transmission Temperature Sensor "A" Circuit High. I also have a blinking tow / haul mode light on the end of the
I suspect the sensor is faulty. When the transmission is cold, I can get the sensor to work OK.
Anyone have an idea as to where this sensor is located?
I really would prefer to replace this sensor myself rather than bring the car into the dealership for a few days and some flailing...
Old Aug 6, 2007 | 02:54 PM
385seriesHemi's Avatar
385seriesHemi
If you can get to library by you that has AllData online. Just look your truck up and it should tell you.
Old Aug 7, 2007 | 07:45 AM
projectSHO89's Avatar
projectSHO89
The TFT is part of the solenoid block and is not individually replacable.
Replacement of the solenoid block involves dropping the pan and removing the valve body first to gain access to the solenoid block.
Steve
Old Aug 7, 2007 | 07:48 AM
Casey's Avatar
Casey
I believe it is individually replacable on the TorqShift trans. It is on the solenoid body inside the pan.
Old Aug 9, 2007 | 07:31 AM
projectSHO89
Oops, missed that "TorqShift" detail, was looking up the 4R100.
Yep, the sensor is individually replaceable. Don't have to drop the valve body, either.
Steve
ace2f150
1997 - 2003 F150
Mar 29, 2017 11:01 PM
Big Hurt
Jul 10, 2016 12:21 PM
BLADE35
Oct 1, 2013 01:18 PM
golfingnut
6.4L Power Stroke Diesel
Jul 27, 2012 07:19 AM
03KingRanchF250
Mar 31, 2007 01:25 PM
