e4od diagnostic
Old Jan 21, 2016 | 08:51 AM
POLARISrider500's Avatar
POLARISrider500
e4od diagnostic
Hello my 1993 f150 has a shudder/ shake at low speeds accerating, extended cab long box so a 2 peice drive shaft. i got a transmission flush with mercon 5 and i know nothing about this transmission. Should i take out my rear drive shaft out and test it in 4x4 for a small amount of time and see if it goes away? I want to make sure it is my transmission and not my drive shaft it was at 35 to 45 not its at right on take off and kinda all over. The motor wass unbolted i believe at 30000 for the oil pan on my service records? thought this was weird kind of annoying and truck just about only has 58000 miles.
Old Jan 21, 2016 | 01:19 PM
Lead Head's Avatar
Lead Head
Chock the tires, put in neutral and check the u-joints for play.
Old Jan 21, 2016 | 01:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The only way to check the ujoints is with the driveshaft out of the truck. You'll miss many bad ones if you check it while still installed in the truck.
Old Jan 21, 2016 | 09:04 PM
POLARISrider500
all u joints solid and new carrier bearing. replaced center u joint 10000 miles ago when i got the truck, i felt all the u joint when i replaced the center one
Old Jan 21, 2016 | 09:06 PM
POLARISrider500
just want someone elses opinion on what to do next
Old Jan 21, 2016 | 09:25 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
unbalanced tire,broken belt? failed u-joint since replaced/inspected out of truck?
loose engine/trans mount bolts/failing mounts? cheap/free things first.check then check again,even if you think something should still be good.insure it's still good.
Old Jan 21, 2016 | 09:28 PM
POLARISrider500
apprciate i, i know it is really hard on the transfer case but would i be okay to see if my drive shaft is out of balance to go down the road once without the rear driveshaft?
Old Jan 21, 2016 | 09:36 PM
FORDF250HDXLT
i didn't know that was hard on the t-case.iv had to remove a rear drive shaft a few times over the years and run 'er in front wheel drive to get home before.
Old Jan 21, 2016 | 09:37 PM
POLARISrider500
i was always told it was, i know someone that blew one but he was kind of asking for it, front wheel drive peel outs...
Old Jan 22, 2016 | 10:27 AM
POLARISrider500
i would not think it is a tire if it is right off take off acceration, did it with the old tires also
Old Jan 22, 2016 | 10:28 AM
POLARISrider500
they were balanced twice
fightlivefree
Jun 15, 2017 01:00 AM
bfaulkner
1997 - 2003 F150
Nov 17, 2011 04:24 PM
clgreer
18
Jan 28, 2008 10:20 AM
tps93ranger
1983 - 2012 Ranger & B-Series
Dec 30, 2006 10:18 AM
PERFORMANCE RED
1978 - 1996 Big Bronco
Mar 10, 2006 06:47 PM
