At 110xxx miles I had to replace it with a reman. shaft due to the "ball and cup" area between the 2 front U-joints. Then at 150xxx miles i lost the rear U-joint on the shaft, now at 156xxx miles I lost the whole shaft again with the "ball and cup" area between the front 2 joints.
What could be causeing me to wreck the shaft?
My Bronco is not lifted or modded in any way. The first shaft went out before i had the tranny rebuilt at 130xxx miles so i doubt it has anything to do with that.
Would a tore transmisson mount do somthing like this? I don't know what else could be causeing my problems.
Does your driveshaft still move in and out freely, if not(it's frozen in place), and when you hit a big enough bump, it doesn't lenthen to say conected and just pops off, but if that isn't the problem, then you could try upgrading to stronger u joints and at least those should break anymore.
Was the shaft in question ever separated at the slip shaft for any reason and reassembled? I only ask because they are balanced with the front and rear sections assembled and if the slipshaft is separated and not clocked as it had been when the D/S was initially balanced the balance could be off. Personally, I think this is a longshot anyway since you would most likely have a vibration issue before this scenario would actually ruin the D/S. I just throw it out there as a possibility since there isn't much to substantiate the premature failure from what you have said.
