Surface rust spots
Old Jan 21, 2016 | 08:32 AM
Buck 1's Avatar
Buck 1
Surface rust spots
I have a 2012 F-150 " Lariat " that I purchased in February, 2013. My 3 yr., 36 month warranty expires soon. After hosing it off yesterday, I noticed several tiny spots of rust on the white paint. Most of it is on the tailgate, but there are several spots on every panel and door of the truck, which is a crew cab. There are only 28,600 miles on the truck, and I take great care of it. What do I do now? Any way to remove this rust? Is this a common problem? Thanks in advance for your help!
Old Jan 21, 2016 | 01:22 PM
fordman19762003's Avatar
fordman19762003
I would bet it is rail dust, which comes off with a clay bar or some light rubbing with polishing compound. I had the same issue with the last white truck I had. I noticed them and about freaked out until I found the same specs on plastic parts. An afternoon with the clay bar and some polishing compound took care of the spots. I did have to go over the truck a couple of more times after more appeared but eventually got everything.
Rail dust is pretty common on vehicles that were transported that way. The metal dust sticks to the clearcoat and then rusts after being exposed to moisture or salt. It really can't be felt by the hand and only shows up on light colored vehicles.
Old Jan 21, 2016 | 04:17 PM
johnnypete's Avatar
johnnypete
Cool premature rust
I have a 2010 f150 xlt and the bottom of my tailgate has a major rust problem .My 5 year warranty ran out in august and ford will not help . I am very dissapointed and will not buy a ford again
Old Jan 22, 2016 | 05:49 PM
Buck 1's Avatar
Buck 1
Thank you, fordman 19762003! I did panic when I first saw the tiny rust spots on my white truck. I will use a clay bar on it when the weather warms up, and am confident that will do the trick. I appreciate your help......
Old Jan 23, 2016 | 10:02 AM
paredneck33's Avatar
paredneck33
Not sure why people think any manufacturer should or would do anything for an issue after the warranty on said item expires. Yeah it sucks when this kind of thing happens, but that's life. Not sure how many miles are on your truck. But the fact is that the warranty expired. So why would you think that Ford should pay for this. No manufacturer would. Nor do any of them offer lifetime rust through warranty.
Tbc420
Feb 24, 2018 08:13 PM
Buck 1
2009 - 2014 F150
May 10, 2015 11:27 AM
EM60
2004 - 2008 F150
Jul 25, 2007 09:26 PM
icemantr5
2004 - 2008 F150
Mar 14, 2007 07:58 PM
MightyJoe
1997 - 2003 F150
13
Feb 8, 2005 04:45 PM
