Rust in bed...
Old Jul 5, 2007 | 01:45 PM
EM60's Avatar
EM60
Rust in bed...
Has anyone noticed any rust where the bed is welded below the tailgate and above the bumper? Just happened to look in there and was amazed there was rust aleady, especially because I am **** over the trucks cleanyness. I have also noticed orange stains comming from under the door hinges(2).
Old Jul 24, 2007 | 07:54 PM
amish77's Avatar
amish77
Might be worth a look on the hinges. I'd try some rust stop primer with a color matched top coat, followed by clear. Be generous with taping off. The spray paint should cost you in the 15 dollar range, probably 20 with the tape.
Old Jul 25, 2007 | 09:01 PM
4DOORSR's Avatar
4DOORSR
I have rust in the same spot and under the plastic pieces that run on top of the box. I'm starting to get a stain running down the side and it won't wash off. Anyone know what will kill rust stains and not my paint?I won't have time to fix the rust until winter.
Old Jul 25, 2007 | 09:26 PM
black04lariat's Avatar
black04lariat
4DOOR: If you want you can take a clay bar and use it properly(clay bar you can get at an auto parts store and use it wet) on the rust stain running down the side and it should take it off. I have done it to previous cars for rust stains. The stain I used it on wasnt bad. Not sure for you, it is worth a try and removes the impurities from the paint. I like to do it to my vehicles at least once a year, makes the paint perfectly smooth. Oh yea, then wax the area you clayed after.
