stripped intake ARP stud
Old Jan 3, 2016 | 08:47 AM
jrockdiddy's Avatar
jrockdiddy
Hey guys, was putting on my new weiand stealth intake manifold this weekend, bought the ARP studs to use. when i was torquing down the front stud which is closer to the thermostat housing, it stripped out of the head. see pic below. Wondering what my options are without removing the intake and using heli-coil. What a pain in the butt.....
Old Jan 3, 2016 | 09:53 AM
drptop70ss's Avatar
drptop70ss
Take a break, take it apart in put in a helicoil. Half baked repairs will only delay getting in there to do it right.
Old Jan 3, 2016 | 10:48 AM
jrockdiddy's Avatar
jrockdiddy
took out the stud, grabbed a longer bolt, wrapped some thin copper wire around the threads and was able to torque it down to 15-20 ft lbs. gonna have to do for now. Im not about to tear into the intake again. not my dream motor anyways. wanna get the truck driving again, and build a 408 stroker as i am enjoying the truck
I haven't put coolant back in the truck yet. when i do, if the intake leaks right around that bolt, then i'll consider redoing the intake and heli-coil the head.
Old Jan 3, 2016 | 11:59 AM
drptop70ss's Avatar
drptop70ss
Good luck, but really taking your time that is an hour job to put in a helicoil, especially with no water in the block. I don't have the kind of luck to gamble with fixes like that, no doubt I would be 3 hours from home when it let loose.
Old Jan 3, 2016 | 12:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Sure doesn't look like the intake surface is parallel to the head surface. I'd be asking myself WHY the bolt stripped.
Old Jan 3, 2016 | 12:24 PM
toby tough's Avatar
toby tough
I agree with Ross. There is a small gap there that probably shouldn't be. A good fix on aluminum is a Timesert. Better than a Helicoil. Not sure it would work in this application but well worth checking into. They use them on the 5.4's and such when they blow out a sparkplug. I've done the wire thing in a pinch and they hold for a while
Old Jan 3, 2016 | 01:28 PM
jrockdiddy's Avatar
jrockdiddy
I will check out that gap when I get home today that does not look right.
Old Jan 4, 2016 | 04:04 PM
jrockdiddy's Avatar
jrockdiddy
I think it was a weird angle I took the picture. There doesn't seem to be a gap. The gasket makes it look like a space
Old Jan 4, 2016 | 04:56 PM
Nicholas+'s Avatar
Nicholas+
I would definitely take care of that correctly now if it was me. Eventually you will have to fix it, possibly after the first start up. I'd suggest to do it before you add the coolant and all that. Like mentioned, its a quick fix at this point. It will be more work to do later. But its your truck, do what you want.
Personly if I took a short cut I wouldnt be able to stop thinking about it sitting there like a ticking time bomb. I guess I think that way because I did those things when I was young and learned its better to just take the extra time to do it right. Good luck with it either way.
bryan_johnson
18
Mar 3, 2019 09:13 AM
daveengelson
17
Jul 31, 2016 01:49 AM
Reed
13
Feb 2, 2009 06:40 PM
afinepoint
Jan 2, 2004 11:31 PM
51truck
Aug 1, 2002 04:44 PM
