Sponsored by: Real Truck
Horn question...
Old Jan 2, 2016 | 07:31 PM
CNC's Avatar
CNC
Horn question...
Happy New Year everyone!
I have a 2003 Ford F250, 4x4, 5.4L, with 130,000 miles. The truck has been well maintained and is in great shape.
The truck sat between the holidays and I went out today and noticed that my horn did not work. I noticed that the cruise control did not work either. Figuring it was a fuse I went to the auto parts store and replaced the fuse. The horn worked, but it seemed like one of them was out. The cruise control is still not working, but at least I have my horn, well maybe.
A few hours later I hear a horn blowing outside and it's mine. I removed the fuse and it stopped. I reconnected the fuse and noticed that the horn is stuck, however if I tap the horn it will stop, but if I hit it again, it gets stuck.
For now I've removed the fuse, but does fully stop the power loss? I did a little reading and found that the clock spring inside the wheel may be bad? I also read that there is no horn relay and that's why I'm asking about power and if my battery is being drained even though I've removed the fuse and stopped the horn?
Old Jan 3, 2016 | 02:14 AM
Yahiko's Avatar
Yahiko
Time to replace the clock spring I would have to say. But
to be sure you should test the circuit and DON'T put the meter
probes on the one for the air bad it can and most likely will
go BOOM in your face. Your far better off to remove it while testing.
Have a look at these 4 PDFs. Read it all first. You are responsible for
you safety and well being.
Sean
6.0L Tech Folder
Old Jan 3, 2016 | 02:02 PM
CNC's Avatar
CNC
Thanks for the information and pdf's.
In regards to the clock spring, on a scale of 1 to 10, where would it fall for someone who is not a mechanic?
Looking at the first pdf, it appears to me that by disconnecting the fuse would eliminate any power to the horn relay? Meaning that I should be fine and would not be draining my battery? I don't know when I'll get to this and wanted to make sure that just removing the fuse will stop the circuit.
Old Jan 3, 2016 | 05:18 PM
Yahiko's Avatar
Yahiko
Yes pulling F2.37 will do the trick.
It's an easy changeout. You will need only a few tools.
You also need a new clock spring along with a new steering wheel bolt.
I really think you can reuse the old bolt but you know how it goes.
Tools that you will need. Torque wrench, medium gear puller and a torx
bit for the wheel bolt.
Later tonight I will post the PDF that has the steps you need to take.
The only really danger point is the air bag. Think of it as a bomb.
AFTER ALL IT IS A BOMB.
Sean
6.0L Tech Folder
Old Jan 3, 2016 | 05:23 PM
CNC's Avatar
CNC
Ok good, at least for now I'm not draining the battery. I checked the battery today and it's at 12.2.
Thank you for the pdf's, I'll look at them after you post them. Maybe I'll tackle the job, any idea of how long it takes? You're scaring me with the air bag, but I guess as long as you remove the battery and let it sit, should be fine?
Where can I find the Motorcraft part numbers for the clock spring and the steering wheel bolt?
Old Jan 3, 2016 | 05:49 PM
Yahiko's Avatar
Yahiko
For the air bag deactivation you pull a fuse. I post all the steps you need.
For a first time job your maybe looking at an hour.
I would if you have access to a battery charger put one on it.
Your best bet on the part numbers is to use your VIN number to
order from. All clock springs are not the same.
The best price I got on that part was from Ed at >>> FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
If you do call Ed let him know I sent you and have not forgotten that
I need to send him some photos. If you go t a dealership they will charge a lot more.
But I will make sure that you have all the info I have access to and anything else I can think of.
One odd note most steering wheels use a steering wheel puller and in our case we use a gear puller
instead. Just one of the odd little tips.
Sean
6.0L Tech Folder
Old Jan 3, 2016 | 08:49 PM
LindenBruce's Avatar
LindenBruce
It could also be the switch just behind the steering wheel cover over the airbag. That's what happened to me. My horn started sounding on a hot day and would not stop. The cover over the airbag was fragile and had failed to hold it's shape. I ended up buying an airbag assembly to fix the problem. B.
Old Jan 3, 2016 | 09:10 PM
CNC's Avatar
CNC
My horn cover is pushed in a bit from years of use.
Anybody have a diagram of what's under the cover? I know the airbag is in there, but not sure what the switch looks like.
Is there any way to test the switch vs. the clock spring? I would imagine that the switch is easier to change and wouldn't require removal of the steering wheel?
Old Jan 3, 2016 | 09:17 PM
LindenBruce
This is the pressure bad right behind the blue Ford oval in the center of your steering wheel. I tried to find one for purchase and not successful. It is easier to replace the airbag then the clock spring. Just two small bolts on the back side of the steering wheel and a wire connector. But, you will either have to find a used airbag assembly or buy new. And new is not cheap. B.
Old Jan 3, 2016 | 09:22 PM
LindenBruce
P.S.
I would NOT be applying a volt meter to ANY electrical connectors on the back side of this assembly to test the switch. If you get the wrong connector you could activate the airbag right in your face. NOT good!!!!
BUT, you can pull this assembly from the steering wheel, put your fuse back in, and see if the horn sounds. If it does still sound then you have a clock spring issue. If not, you know it's the pad in the airbag assembly.
There is a repair procedure on the net for fixing the pressure pad. BUT, it involves toothpicks and silicone. I don't know about you, but I don't want miniature wood stakes flying into my face if the airbag were to go off in an accident. So I will NOT post a link to that fix. That is on you if you go out and find it and do that repair. B.
Old Jan 3, 2016 | 09:51 PM
CNC's Avatar
CNC
So the airbag includes that pad/switch?
How much is an airbag?
Old Jan 3, 2016 | 10:02 PM
LindenBruce
Yes. It is sandwiched between the airbag AND the outer cover with the blue oval. I don't believe the switch is available separately from the air bag. As that would mean people would be working on air bags and who knows if they would do it correctly. Liability and all you know. B.
Old Jan 3, 2016 | 10:04 PM
LindenBruce
Perfectly good pulls from salvaged trucks seem to be starting at 90 dollars on ebay. That's where I got my replacement. B.
Old Jan 3, 2016 | 10:07 PM
CNC's Avatar
CNC
Thanks for the pic.
You'd think the switch (#2) would be available separately, it's not part of the airbag? Anybody know if the switch is available separate of the airbag?
My outer cover is depressed, where the blue oval ford emblem is located. My horn has seen a lot of action over the years, lol.
Old Jan 3, 2016 | 10:33 PM
Yahiko's Avatar
Yahiko
Sadly that switch is non-servicable.
LindenBruce is right about the meter and setting off
the airbag. That also goes for the seatbelt pretensioners
aka: The buckle. They go BANG too. Not as bad as an airbag
but still enough that your not ready for it you may need a
fresh set of shorts.
Now that I am back home I can get to pulling the PDFs out for you.
Sean
6.0L Tech Folder
