Yes, there were signs of it leaking into the intake. A little damp and would spike pressure in the cooling system when towing the camper so I decided to delete it and then dummy plugs, stand pipes, oil cooler, studs and coolant filter as long as I had the hood off.
Next I need a tuner that doesn't interfere with ANYTHING I plug into the OBD port. I am leaving the Edge disconnected for a while just so I can monitor things with my Torque Pro app.
