Next project should be putting a Ford drivetrain into the hot rod
That would be way to much work!
Originally Posted by MisterCMK
Is your truck done yet Cory?
If it is done then it is a dirty trick leaving parts off including the hood! Trying to trick me into storing his truck inside where it is warm all winter.
Waiting on some injectors to get here that we are replacing. They should be here this week. Everything else is done. So hopefully finish it up this weekend.
Originally Posted by Big-Foot
Good morning guys!
Another brisk morning I see...
At least it's sunny out!
what else you going to do on those cold weekends? you can still drink beer and turn wrenches, although knowing which wrench to turn after a while might be the problem
A bit chilly again this morning! Making ice for fishing!
Yup, a dirty trick Troy! Dang you are catching on. I purposely sabotaged it so I can come out on weekends drink beer and get free heated storage. Crap I better get it fixed now.
I ordered four re manned injectors from RAE. We got the truck running and it starts to loose fuel and die. Did bubble test and found a LOT of bubbles on passenger side. Replaced o-rings and copper washers reinstalled and had the same. Only thing left is a faulty injector. They Next Day Aired four more and a RMS tag for the others. Should be here today then get them to Troy.
