High Idle aborts??
Old Dec 31, 2015 | 01:21 PM
adhanda's Avatar
adhanda
High Idle aborts??
Hey all, I've done some hunting and can't find anything explicitly answering a SEIC related question I'm running into...
Background on the vehicle: at my volunteer fire house we have a 2013 F450 Chassis cab based ambulance. When the temps drop into the 30s or below (fairly common here in Maryland), and the truck idles for more than 5 minutes (being on scene of a call), the cabin starts losing some heat (the patient compartment keeps pumping heat though). This can be completely remedied by revving the truck up to ~1200rpm, and within seconds heat is strongly flowing back into the cab.
Additional long story short, the spec writers for our build forgot a number of things, one of which was a high-idle switch. Subsequently, I followed the wiring instructions found here (and elsewhere) and wired a resistor inline and wired Upfitter #4 to activate the high idle.
The operation of it is not correct though. Assuming everything is up to temp, if I activate the parking brake (in park), and turn on Upfitter #4, it will raise the idle to ~1300, hold it there for 2-3 seconds, and then drop back down to normal idle. Almost as though something in the "requirements" for high idle dropping out (like hitting the brakes or moving the shifter when it's doing a manual regen).
Any ideas on this? Is there another way I can trouble shoot this?
Thanks!
Old Dec 31, 2015 | 05:56 PM
Just Strokin's Avatar
Just Strokin
Have not seen nor heard anyone experience this problem. I see there is a problem with some F550 and F650 with the 6.8 engine having it shutoff form body roll...
https://www.fleet.ford.com/truckbbas/non-html/Q-244.pdf
Try emailing the Body Builders at Ford and see if they can give you an answer.
bbasqa@ford.com
Old Dec 31, 2015 | 10:30 PM
Andrew010's Avatar
Andrew010
Bad resistor? I used a potentiometer instead and can turn it up or down as I like.
I will say if I turn it too far up it kicks off high idle kinda like yours does. Maybe u have the wrong ohm resistor.
Old Jan 1, 2016 | 06:00 AM
troverman's Avatar
troverman
I would suggest it's the resistor. Replace it and check any soldering connections. Also, the high idle kicks off if the gas or brake are touched.
Old Jan 2, 2016 | 07:01 AM
adhanda's Avatar
adhanda
thanks for the quick responses! I'll replace the resistor and see if that fixes it... if not, I just ordered one of the potentiometers as well to test
4Wheelgreg
6.7L Power Stroke Diesel
Feb 26, 2018 07:06 AM
Iaff113
Mar 3, 2014 11:20 AM
Midnight Ride
Jun 15, 2013 06:05 AM
EXbowtieguy
Oct 31, 2011 09:50 AM
UNTAMND
Sep 1, 2009 11:14 AM
