Idle Question
Old Aug 31, 2009 | 09:04 AM
UNTAMND's Avatar
UNTAMND
Idle Question
I couldnt find anything quick on a search similar to my question, so here goes.
I have a 2000 truck, and it runs great. Lately when idling, it for no aparrent reason will raise the idle to around 800-950rpm and hold it there until I blip the throttle, or touch the brake. Now I kow the newer trucks after idling for a while will raise the idle for a little bit and then back down, butmine has never done that. Its just got this weird issue and I dont like it revd up at almost 1k for half hour at a time whenever it feels like it; Thats why I bought the apcm idle controller.
Any insight on what could be the issue, maybe the throttle position, or something.
Old Aug 31, 2009 | 09:20 AM
Pocket's Avatar
Pocket
If you let them idle long enough, our trucks will raise the idle. Perfectly normal, and it's a way to protect the engine from wetstacking.
Old Aug 31, 2009 | 08:48 PM
UNTAMND's Avatar
UNTAMND
I understand that feature, but I also thought my truck didnt have that feature. But my question and concern is that when it raises the idle, it is supposed to come back down after a short time or raised idle. My truck will not reduce the idle after any amount of time.
My truck will raise the idle, and stay raised until I either touch the brake or the accelerator.
Why dont my truck raise the idle, and then after whatever time, reduce back to normal idle.
Old Sep 1, 2009 | 09:27 AM
Pocket's Avatar
Pocket
That's the way it functions. The high idle feature is built into all of these trucks. In the winter time, it kicks on with oil and air temps. In warmer weather, it kicks on with extended idle time. In both instances, the way to shut it off is to touch the brakes or the accelerator. It's a built in safety feature, as extended low speed idling can have adverse effects on these engines, even with a fully warm engine. That's how wetstacking occurs.
The AICs are just so you can have control over it, and kick it on and off with a flip of the switch. Say for instance you need to power something with your truck.... and it's summer time. You can either wait 30 minutes or an hour for the high idle to kick in, or you can flip a switch and have it instantly when you need it.
Old Sep 1, 2009 | 10:48 AM
UNTAMND's Avatar
UNTAMND
I understand the whole wetstacking thing, I understand why the truck does the idle thing. BUT, I only need to wait 5 min in 75 degree weather and my idle raises up. Thats why I was concerned somethign was wrong.
My idle controler was bought for the reason you said, so I can run a pto eventually, and I currently use it a lot for teh charge protect, when using my 12000lb winch. The ford apcm works flawless, I just get frusterated when the truck idles up by itself and NEVER comes back down. I thought that the idle raised only for a few min and then went down to normal idle for a while then raise again for a few min then normal idle; Not stay at 900rpm forever until you push the brake.
How is it supposed to work.
Old Sep 1, 2009 | 11:13 AM
Pocket's Avatar
Pocket
Is your air intake temp sensor working properly? It should take a bit longer to go into high idle at those temps, especially if the engine oil is fully warmed up too.
If the intake temp sensor is unplugged, or if it's reading the wrong temperature, then I could see it going into high idle too soon.
No, that's not how it functions in stock form.
Yes, this is how it's supposed to work. But again, at the temps you are seeing, it shouldn't kick on after only 5 minutes of idle time.
Old Sep 1, 2009 | 11:14 AM
Pocket's Avatar
Pocket
Oh, almost forgot... a bad EOT (engine oil temp) sensor can also be the culprit.
