93 7.3 idi e4ohno
Old Dec 30, 2015 | 07:01 PM
plowboycowboy's Avatar
plowboycowboy
93 7.3 idi e4ohno
Ok, so i replaced the shift pack, tps, vss, pcm, and the position sensor? On the drivers side of the trans. The guy i bought the truck off of had cut the obd connection off so i havent been able to read codes.... yet.
My problem was at first: trans would be in linp mode and if i ahut it off and turn it on then itd work good. It did that for a week and then just completely went potatoe. After that inreplaced the pcm, tps, vss, shift pack and thenpart on thenleft aude of trans. Now for not having much time/money (truck is called "child support express" for a reason) i refuse to take it to a mechanic. Id like to get some sort of pointing firection before i go out and buy a obd reader. And whatnwould be a good obd reader?
Old Dec 31, 2015 | 08:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
there is no need to buy an OBD reader.
why not try jumping the wires in the test port and reading the flashes on the dash?
connect the grey/red and white/pink wires.
test light alligator clip to the positive side of the battery, and the other end of the test light to the pink/light green. if connected properly, the test light will just barely come on.
get inside the vehicle and turn the key to the run position and count the flashes of the check engine light. it should give you a series of either 2 or 3 digit codes: 2 flashes, 7 flashes is a 27 code, 3 flashes, 3 flashes, 2 flashes will be a 332 code.
write down the codes and get back to us and we should be able to figure out what the deal is.
sprinklers
39
Mar 28, 2015 08:18 PM
TradMercs
19
Dec 29, 2010 10:05 AM
EMD_DRIVER
Sep 9, 2008 11:45 PM
mrblue01
Dec 1, 2001 01:33 PM
Ray D
Jun 8, 2000 07:42 AM
