Blue smoke and chugging
Old Dec 29, 2015 | 02:11 PM
BrendanFitz's Avatar
BrendanFitz
I have a 94 f250 7.3L turbo diesel. It is starting to chug more and is smoking a ton. The smoke is kind of blue. Any ideas of what it can be?
Old Dec 29, 2015 | 02:23 PM
PlumCrazy7's Avatar
PlumCrazy7
Sounds like you are losing rings. How many miles? Does the smoke clear up with throttle?
Old Dec 29, 2015 | 08:22 PM
BrendanFitz
149k miles and no it gets thicker, unless I shut it off and turn it on 2 or 3 times
Old Dec 29, 2015 | 08:41 PM
Macrobb's Avatar
Macrobb
Um... explain more.
Without the "turn it off and on" thing, I'd assume the IP's going; at the very least you can advance it a bit and see if it helps.
Old Dec 29, 2015 | 09:13 PM
BrendanFitz
Originally Posted by Macrobb
Um... explain more.
I feel like it's a combo of glow plugs and injectors.
Old Dec 29, 2015 | 09:23 PM
Macrobb's Avatar
Macrobb
Glow plugs only affect when it first starts; once the engine's run for 30 seconds or so, the GPs have zero affect on anything.
Injectors... could be. I'm sure replacing them wouldn't hurt.
Old Dec 29, 2015 | 10:17 PM
BrendanFitz
Injectors... could be. I'm sure replacing them wouldn't hurt.[/QUOTE]
It'd hurt my bank
Old Dec 30, 2015 | 12:23 AM
PlumCrazy7's Avatar
PlumCrazy7
At $200-$300 for an entire set, they are probably the cheapest diesel injectors there are.
Old Dec 30, 2015 | 07:52 AM
BrendanFitz
Any recommendations on what injectors to get?
Old Dec 30, 2015 | 12:33 PM
PlumCrazy7's Avatar
PlumCrazy7
Investigate your area, there should be a quality diesel shop that farmers, construction companies, etc. use. This type of shop has experience with older stuff and can get you quality parts. Alternatively, you can go to idiperformance.com, a lot of people swear by his stuff.
Old Dec 30, 2015 | 06:36 PM
Macrobb's Avatar
Macrobb
Justin @ R&D actually has new injector nozzles custom made, something that few others have. The people making injectors(like delphi) stopped doing it a year or two ago, so now it's just rebuilt ones out there, mostly.
Justin had a set reverse-engineered and new ones made, and they seem to work nicely. I'd buy from him, because I've had plenty of issues with used sets... thought I was getting a deal, and 10K later I've got issues.
Old Jan 1, 2016 | 11:32 PM
speedwrench72's Avatar
speedwrench72
the chugging has me thinking bad cam or valves, you can get a compression tester that fits in the glow plug hole. run engine for a trip into town then remove one glow plug at a time and test compression, remove the FSS wire so engine will not start...this will tell you the condition of the engine....if it sounds like its back fireing into the intake it could be burnt or bent valves from broken off tips of gp's. hope you figure it out..
waystro
Mar 2, 2012 08:45 PM
big island
Aug 25, 2010 10:43 AM
Blueovals&Blacksmoke
Sep 25, 2008 06:22 PM
Dieselamour
Oct 13, 2007 08:44 PM
ALL BOY
Dec 5, 2005 07:18 AM
