help id numbers
Old Jan 19, 2011 | 03:03 PM
jah65's Avatar
jah65
help id numbers
To NumberDummy or anyone that can help.
I have 1981 Ford F-150 Rangerxlt w/351m/w/motorcraft 2150. My vin. is 1FTDF15G8BRA15050. My door sticker wb/133 F151 CT4 K 17 1981 DSO 71 F0082 T0401. Tag # on rear axle WDM DC 0L03, 247 9 5322B. Trans. PJA CJ12F18,E11PSA010422. This # I forgot where I found it D7TP-7A020-DA. I have part of # stamped on the side of card has no tag 62403A. This # off tag on firewall 13-154 F15BRA15050 under that cx 133 bdy 4 3 under that A5T dlx low rge xlt under that x s both. This # off emission sticker E1TE-9C485-KA DAR. Can you help I.D. this numbers. Thanks.
Old Jan 20, 2011 | 04:26 PM
LxMan1's Avatar
LxMan1
Your VIN number: 1FTDF15G8BRA15050
World Manufacturer Identifier - 1st, 2nd, 3rd Positions:
Manufacturer: Ford Motor Company, USA
Make: Ford
Vehicle Type: Truck (Completed Vehicle)
Brake Type and GVWR Class - 4th Position:
Brake System: • Hydraulic brake system, Class D, GVWR 5,001-6,000 pounds, None
Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions:
Line Series: F-Series - F150
Chassis Type: 4x2
Body Type: Pickup - Regular Cab
Engine Type - 8th Position:
Engine: 5.8L (351cid)
Cylinders: V-8
Fuel Type: Gasoline
Horse Power: TBD
Model Year - 10th Position:
Model Year: 1981
Assembly Plant - 11th Position:
Assembly Plant: Hermosillo: Hermosillo, Mexico
Production Sequence Number - 12th - 17th:
Sequence Number: A15050
D7TP-7A020-DA is the transmission dipstick for a truck C6.
wb/133 = 133" wheel base.
You sure that the 0L03 is not 3L08? That would mean 3.08 limited slip.
RodSUT
33
Sep 11, 2015 02:52 PM
3 QTR FUN
Mar 15, 2012 09:01 AM
xpel tech
2010 - 2014 Ford SVT F150 Raptor
Jul 14, 2011 11:26 PM
xpel tech
2009 - 2014 F150
Jun 1, 2011 06:35 PM
overton19
Aug 4, 2003 10:09 AM
