Which Clutch?
Old Dec 21, 2015 | 05:13 PM
orich's Avatar
orich
I found when going with the Centerforce stage ll clutch setup had to cut the clutch linkage push rod 1/2" shorter to be able to adjust the free play travel.
Orich
Old Dec 22, 2015 | 05:13 AM
GaryKip's Avatar
GaryKip
orich, how long have you been using that clutch? Do you use your truck for off road ? and do you think it was worth it, looks kind of spendy?
Old Dec 22, 2015 | 08:25 AM
orich's Avatar
orich
About 09 put it in and no have not used it for any off roading much in the last 20 yrs.
So far so good with the centerforce. I was running the 11.5 long style but due using a NV4500 o/d have been using the a Chevy clutch disc with a ford pressure plate that works out good. But wanted more clamping force with the smaller clutch disc.
Theirs is a fast release for like drag racing, don't care for it as it's a short push on the pedal, and the normal full release of the pedal.
Orich
Old Dec 22, 2015 | 02:57 PM
JEFFFAFA's Avatar
JEFFFAFA
Back in the day of the Fox Chassis Mustang Ford motorsport (FRPP) used to have a part number on the Centerforce pressure plate and on the dual friction disc. Back then I was told one side was ceramic. Which needed to be heated up to grab good and went through flywheels quicker. I've never had one personally but this is what I was told. They look different than the one in your pic Steve. Like this:
Old Dec 22, 2015 | 09:54 PM
Alex from GA's Avatar
Alex from GA
What do you need a heavy clutch for with a 240? You'll be very happy with an 11" diaphragm clutch.
Old Dec 22, 2015 | 10:26 PM
ultraranger's Avatar
ultraranger
Probably for the same reason most of us have an old Ford truck. It probably isn't something that most or even all of us "need" but, it was because we like them and wanted them that we have them.
--most changes on a hobby vehicle are because you want it and generally not a case of because you "need" it.
It just comes down to preference in what components you want to add and how much you're willing to spend to get it.
Old Dec 23, 2015 | 12:54 AM
Red Mercury's Avatar
Red Mercury
I was thinking the same as you. I have a 1967 F100 with a 240/3 speed and the clutch has been replaced a couple of times ONLY because dearly departed dad used to to pull a 16 foot bumper hitch stock trailer and he had to ride the clutch a lot to get the rig rolling. He was using a toy truck to do a work truck's job. Under normal conditions that 240 will do just fine with a stock clutch.
Old Dec 23, 2015 | 07:26 AM
orich's Avatar
orich
Yup that will do it.
He should have had a 4 spd trans with granny first with gear.
Orich
Old Dec 23, 2015 | 10:20 AM
Gembone's Avatar
Gembone
I have the 300 with a 4spd granny and I went with the 11" diaphragm clutch. I have no issues at all.
Old Dec 23, 2015 | 10:24 AM
yetiman38237's Avatar
yetiman38237
The only issue I ever had was the clutch pedal being lazy and having to "toe" it back in place. When I put new clutch in I haven't had that issue anymore. Doing some reading on diaphragm style revealed that is a pretty common issue with the easy pedal.....I do like to grab second sometimes to hear the chirp but not enough to go with a centerline.....
Old Jan 1, 2016 | 09:51 AM
MrBlue6869's Avatar
MrBlue6869
WOW!! Great info!!! Thanks to you all!! Computer problems have kept me away. I don't really NEED a heavy duty clutch, I do want one that will stand up to occasionally pulling a two horse trailer, or a car hauler with my project VWs or F-100s!! If I understand correctly, the old style three finger grips better than the new diaphragm style. So for my purposes it appears that a stock original style 11 inch will fill the bill?!?
Old May 16, 2016 | 08:28 AM
NS70250's Avatar
NS70250
I know this is an old thread but.... I just learned the hard way that the diaphragm clutch I bought DID NOT WORK. The clutch cover was a hair too big and rubbed the inside of the bell housing - preventing the engine from turning. Had I simply been replacing the clutch I would have found out while rotating the flywheel to torque the bolts, but since it was installed on a new engine that hadn't been lowered into the truck yet, I didn't learn until I panicked that I couldn't turn the engine over while trying to drop in the distributor. Just an FYI for people in the future.
70torino429
Jul 4, 2010 05:21 PM
1957F100
Jul 24, 2008 01:21 PM
socaljerry
Sep 30, 2004 05:58 PM
mhanna77
May 19, 2003 02:26 PM
HardworkinFORD
May 6, 2003 02:44 PM
