E4od Trans Problem Need Help
Old Dec 18, 2015 | 03:53 PM
chrismd188's Avatar
chrismd188
I have searched everywhere and could not find what I was looking for
Truck is a 1996 CCSB 460,4x4,auto(E4od) 218k miles
A couple of months ago I was driving the truck (about 25 miles from home) and the trans started slipping.I limped it home and noticed the fluid was pretty dark and smelled burnt,
I changed the fluid and filter (drained torque converter also) the problem i have now is the truck drives great for about 40 minutes ,shifts good and doesnt slip at all.But after around 40 minutes it starts slipping in every gear .
If I let the truck sit for a few hours it does the same thing all over again
what do you guys think the problem is (overheating?,maybe the tranny is just toast?)
I just think if the trans was junk it wouldnt drive perfect for 40 or so minutes and then just start slipping.
Any opinions would be appreciated.
Old Dec 18, 2015 | 07:39 PM
rla2005's Avatar
rla2005
That E4OD is 100% electronic controlled. Check for codes. Also verify the fluid level is correct (truck warmed up, level ground, in park)
Old Dec 18, 2015 | 07:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's probably too late now, but you may have loose feed bolts. They are located under the valve body.
lakequ
32
Feb 24, 2018 09:21 PM
davidwags3
Jan 20, 2014 10:22 AM
96gizmo
Mar 12, 2011 10:18 PM
Creel
Aug 27, 2008 10:35 PM
mattskn
Jan 8, 2005 09:31 AM
