E4OD trans problem
Old Mar 12, 2011 | 09:15 PM
96gizmo's Avatar
96gizmo
Trailering
E4OD trans problem
I have a 96 powerstroke with 178000 miles. Last couple of days my trans will periodically not downshift and will stall the engine when I stop. I can start it back up and it will drive fine for a while. I have also noticed on one occasion that it would not downshift at wide open throttle on the freeway. When I turn the overdrive off it seems to shift fine. Any suggestions?
Old Mar 12, 2011 | 10:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Check the fluid level. Low fluid can do this. So can a loose or missing internal filter, worn internal seals, or a worn pump.
