Sponsored by: Real Truck
FORD Remote Access SIM ID
Old Dec 17, 2015 | 02:26 PM
Scott Letzelter's Avatar
Scott Letzelter
Hey there, I have a '15 F350 SC I bought new. The ID Card never came with it and the dealership went under. I'm curious as to set up the Remote Access app on my phone but I don't have the card or SIM ID #. Any idea on where in the truck I can find it? I would rather not pay another dealership money to pull it on the computer if I don't have to. Thanks
Old Dec 17, 2015 | 03:45 PM
Just Strokin's Avatar
Just Strokin
Are you sure it has the remote access (RMU) module?...
I was not aware of any truck coming with it installed from the factory.....it would have been a dealer add on.
I am not aware of the 2015 coming with the Vehicle Security (VSS) module that the remote access module plugs into.
You only need the sim id to get Ford tech. He will use it to give you the 4 digit pin to use on the ford access site.
http://www.levittownfordsupercenter....1_23_2015_.pdf
Old Dec 17, 2015 | 10:17 PM
Scott Letzelter
I think I do. It does have the auto stay that I can use with the key. Maybe I'm off then, so in order to use the app on my phone, I still need to buy a module to make it work?. I thought all the sync set up this thing comes with as well as the auto start, it would work with a sim number.
Old Dec 18, 2015 | 05:15 AM
Just Strokin
The standard auto start/remote start is only a basic system that uses the integrated key head/fob to start the truck.
If you have a separate remote start fob and an antenna mounted on the windshield, you would have the VSS in the truck. Most time mounted on the main wiring harness that goes from the dash through the firewall.
If your window sticker shows perimeter alarm, you have might have the VSS. The RMU is totally separate box no usually installed at the factory.
These are the 2 part numbers needed to add the RMU (remote access)
VSS - DL3Z-19A361-A (if not already installed on main wiring harness)
RMU - DL3Z-19A390-B
You can add long distance remote start by adding a window antenna and a separate remote start key fob once you have the VSS installed.
Antenna - DL3Z-15603-C
Bi-directional key fob - DL3Z-15K601-A
or
Kit - EL3Z-19G364-B (Kit Includes (1) DL3Z-15603-C antenna + (2) DS7Z-15K601-F one way remotes)
I know this is confusing but hope it helps.
Old Dec 18, 2015 | 06:24 AM
Pocket's Avatar
Pocket
Look in your paperwork to see if you purchased Remote Access, should be on a "We Owe" form.
Larry is correct, that kit is not a factory installed option. It would have come from the dealership, and they would have charged you for it.
The Vehicle Security System (VSS) part DL3Z-19A361-A serves not only as an alarm with shock sensor, but also as a junction box for the long-range remote FOBS and antenna, as well as the Remote Access RMU unit. It plugs into the DLC (also known as the OBDII diagnostic port). If you can't find your paperwork, look under the dash to see if you have the original DLC plug wrapped up behind and plugged into a Y-port going to a black box zip tied somewhere back there. The Y-port plug would have a new DLC bolted in place of the old one. If you have that, you have VSS. From there you can see if anything is plugged into it, like the Remote Access RMU.
The RMU would have the SIM ID on a sticker attached to the unit itself. Once you have the SIM ID you can take that to the dealer and they can retrieve the PIN....... if they know how to do it.
Old Dec 25, 2015 | 08:07 PM
Scott Letzelter
Thank you guys for all your help. I guess I don't have it. I figured it was already installed from the factory. It has just about every option available, except that one. Haha. Thank you all and Merry Christmas
Scott
super_duty_532
Nov 5, 2023 07:13 PM
ctimrun
Dec 10, 2022 09:44 PM
Stephen Fruscillo
2009 - 2014 F150
21
Jul 15, 2020 12:57 PM
Olytlr
2009 - 2014 F150
Oct 1, 2016 03:16 PM
jhaines10
6.7L Power Stroke Diesel
Feb 1, 2016 06:27 AM
