Worn locks
Old Dec 11, 2015 | 07:28 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Originally Posted by Bird-Dog 250
that's not made in China?
gooood luck with that...
Old Dec 11, 2015 | 08:35 PM
BruteFord's Avatar
BruteFord
Here's another thought....If the truck has power door locks, which it does, did it have a remote entry too? How would I find out if it does? I never got a fob when I bought the truck from the last owner and never thought to ask.
If the truck does have a remote entry how would I code a new fob to work with my truck?
I forgot to ask in the last post...where is a good place to buy a complete lock set that's not made in China?
I don't remember ever seeing an OBS with stock remote entry, doesn't mean it doesn't exist, if any do it's your 97. But I can tell you how it would be programmed and that might serve as a way to find out. I sold used Fords in the early 2000s and they all(90s Fords) programmed the same. To program a remote to a vehicle you turn the key on/off/on/off until the door locks cycle on their own. You'll then click lock on the remotes and the vehicle pairs with the remotes. So if you have remote ability you should be able put it in programming mode even if you don't have remotes. I can't remember the exact number of times you turn it on/off I want to say 10, I never really paid attention I just did it until the locks cycled. But if you try and you get to 15 on/off cycles and the locks still haven't cycled then safe to say the truck isn't set up for remotes.
Old Dec 12, 2015 | 09:52 AM
LeoJr's Avatar
LeoJr
I removed a wire that allowed the remotes to operate the locks while the engine is running. But found that this wire needs to be reconnected before the module will go into program mode to sync additional remotes.
Old Dec 12, 2015 | 10:32 AM
warren561's Avatar
warren561
I believe that no matter manual vs power locks, the key tumblers are the same.
May be easier to buy a new set of door lock cylinders and ignition switch cylinder. Then you have one key for the whole truck.
Originally Posted by warren561
I was able to purchase a keyed set of OE Ford door locks and ignition tumbler for about $80 on eBay two years ago from seller rocket-keys. They're supposedly OE Ford made by the "HURD Lock Company."
I got two door lock cylinders, an ignition tumbler, two plastic black handled keys with Ford stamped on the plastic, and two all metal keys with Ford stamped on them. The look great, fit great, and work great.
uknunn
Apr 13, 2017 03:44 PM
JNG6
Feb 22, 2015 07:41 PM
fifthwheel01
Jul 28, 2009 03:55 PM
wildstang
Oct 21, 2008 04:58 AM
jaredcc86
Dec 5, 2006 09:38 PM
