Sponsored by: Real Truck
Weird door locking problem.
Old Dec 5, 2006 | 06:06 PM
jaredcc86's Avatar
jaredcc86
Question Weird door locking problem.
I have a 99 F 250 with power locks but i dont have the FOB. From inside when i press the lock/unlock button the locks themselves, barely move. From the outside when i stick a key in to unlock the door, its as if its the wrong key and nothing will move inside the lock itself.
I searched through the forums a bit but couldnt find anything on this
Thanks in advance
Old Dec 5, 2006 | 06:15 PM
scole250's Avatar
scole250
Try shooting WD-40 into the key hole? Of course, I'd get a second opinion before you took my advice.
How do you lock your truck...when you are on the outside and want to leave in a parking lot downtown?
Old Dec 5, 2006 | 06:17 PM
jaredcc86's Avatar
jaredcc86
as of right now i drive my other company vehicles when i go into a more populated area. But if i really need to i manually press both locks down inside hte truck and close it up. When i return to the vehicle i literally just pop the back sliding window open and have to crawl myself in there
it isnt fun at all. But i am so confused as to how to fix this.
Old Dec 5, 2006 | 06:22 PM
scole250's Avatar
scole250
Is it the original key? If not, see if you can get the original or find a key that seems to have the least amount of wear on it. I've had extra keys made for my truck by the dealer that barely worked. I'd try to figure out whether it's the key or the lock. What about the passenger side door?
Old Dec 5, 2006 | 06:29 PM
jaredcc86's Avatar
jaredcc86
yeah i've tried original keys, copied keys, passenger door.
When you stick the key in, it acts as if its the wrong key. It wont move to the side at all.
Old Dec 5, 2006 | 06:48 PM
7.3 Powerstroker's Avatar
7.3 Powerstroker
Mine door looks did the same thing all I did was spray some wd-40 into them and they have worked great since.
Old Dec 5, 2006 | 07:11 PM
Rongold's Avatar
Rongold
Door Lock Problem
It sounds like the door lock actuators are going bad. Are the buttons hard going up & down ?? If so, then more than likely the actuators are bad---Not uncommon.
RON
Old Dec 5, 2006 | 07:43 PM
jaredcc86's Avatar
jaredcc86
yeah as i was looking through the same year F150 forums it seems as though the actuators are the problem. Thank you ron
i'll let ya guys know if it fixes the problem
btw, is there anyway, once the actuator is removed, to tell if its bad?
Old Dec 5, 2006 | 09:03 PM
Trouble1263's Avatar
Trouble1263
Are you in a cold weather enviroment?? If so, try some lock de-icer in the lock mechanism. If that works, there is a great fix ( and cheap) in this forum for the actuators
Old Dec 5, 2006 | 09:38 PM
jaredcc86's Avatar
jaredcc86
yeah im in the cold but its been doing even when it was warm. I'll search through here on how to fix them, thanks!
