Electrical issues?
I just bought a 74 F250 4WD, With an old FE block, for a smoking deal, but now im figuring out why it was such a cheap truck...I lost all electrical power the other day when I was driving, pulled it to my job and started digging into it. Well it looked like the truck was running just off battery power. I replaced the Alternator, Voltage regulator, but the truck is still having issues. If I remember correctly, I should be getting around 13-14 volts with the truck running? Because I am only getting 10-12 volts and power drops, I feel like there is a wiring issue some where. What is your thoughts? Any help would be most appreciated
Inspect the wiring and make sure it is hooked up correctly and for any broken wires.
Btw, It would not be unheard of to receive a bad alternator from auto retailers. Just because it is "new" doesn't mean it actually works. The originally installed alternator tested bad, right? Are you sure the battery is OK?
link to much of the associated wiring:
http://fordification.net/tech/images...aster_2of8.jpg
Step one. Voltage with engine off. Baseline v take at the batt. Step 2 voltage running no load, step 3 voltage running with lights an heater on. Should get about 12.5, 14.5, 12-14. If this is not the case we need to check the wires at voltage regulator. With gauges you should have bat voltage on a, with key off nothing on s with key in run battery volt on s. A comes from battery s on gauge cluster type comes from ingnition switch or can be from fuse box. To do a quick test on alternator you can jumper between a and f pins on wiring harness to voltage regular. Do this quick you should get 15ish volts with engine running. If so all ok with wiring and alternator.
If you have a good alternator, good wiring, voltage on a and s terminals and no field voltage probably need new voltage regulator.
Just to help the f signal turns your alternator on and off. Oh and the labels are on the voltage regulator a s f I. It is on your passenger fender well by the starter solenoid.
You may need to do some wiring checks too, there are fusible links one may have blown.
Hope this helps
-k
With any "new" truck there will be some things to get acquainted with. If you bought it cheap that's good, because they ain't necessarily cheap ever again, haha. The one thing that all old trucks seem to have in common is corrosion and rust and therefore high resistance electrical connections. It will just keep getting worse and worse till nothing works anymore. Everyone is probably familiar with cleaning off battery posts and terminals, but there are dozens more connections that are (mostly) just as important and will eventually need the same routine. Try to stay out in front of that saves a ton of aggravation. Trust me. An electrical connection can't be too clean or too well grounded. Every thing on the truck depends on it, from spark plugs to tail lights.
You are going to have to have a strong work light and inspect your truck wiring (among other things) from stem to stern, for some reason people like to really hack up wiring. Try not to compound your current electrical problems, keep the battery on a trickle charger and keep topped off, replace the ground and battery cables now. They start to act like resistors and rob current.
You can do a lot with just a test light and a voltmeter if you know what you're looking for. Check out the YouTube videos for "Voltage Drop Testing" and alternator tests and you'll see what is involved. Real simple stuff. A Ford Truck Shop Manual is a good investment, they made one for your truck and will be invaluable.
Thanks In advance
Seems more like you may have a wiring issue.
If you have the ability to test for continuity (resistance) ensure the following
The alternator charging output has continuity to the battery + side. It does this in a long path, mine goes to the fuse block and back, but they should be connected. There is one or 2 fusible links in there to check.
The stator on your alternator goes to your choke, only your choke. This has no affect on charging.
The field terminal goes to the f terminal of the voltage regulator.
The case should be grounded through the block and you should have continuity to the negative side of the battery.
There are no other alternator connections. Essentially 2 wires does it. Double check that you are on the correct terminals of the alternator. On mine two are close together at 12 (output) and 1 o'clock from the front and one is at 9 o'clock.
Wiggle the wires wile you do this make sure it is a good connection.
Hopefully this helps, good luck.
