I bought a new alternator and hooked it up the way it was before, but the battery isnt staying charged. Does anyone have a diagram of how these wires should be hooked up? or have pictures of theirs?
Yes the voltage regulator can cause that problem, or a bad ground. Make sure where the VR is bolted to the truck that it isn't excessively rusty.
The Ammeter wires are:
Red/Orange stripe
Yellow/Black stripe
They are hooked to the Black/Red stripe wire that goes from the altenator to the starter solenoid. They are placed on opposite ends of a shunt that is inside the Black/Red wire, in the altenator harness.
It is normal for the ammeter to die and no longer read anything after this long. You can test it by hooking it up very breifly to a 1.5v aaa battery just long enough to see if the needle swings. However good news is the ammeter will work from the following vehicles, if you remove the ammeter and transplant it into your truck.
Yes, that helps alot actually. I will look at her tomorrow and see if I cant figure her out. The wires that are back there are so corroded and have so much crap on them i doubt if ill even be able to tell what they are without SERIOUSLY scraping them down. But well see
