1965 butterfly window help.
Old Dec 4, 2015 | 04:34 AM
James88f150/65f100's Avatar
James88f150/65f100
Hey guys I'm new here and I have a 1965 f100 custom cab. On the doors the hinges that hold the butterflies on are broke. How do I go about taking the old ones out and putting new ones in?
Old Dec 4, 2015 | 08:41 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The vent windows? The pivot stud at the bottom edge sounds like it sheared. I bought a truck whose drivers vent window was like that.
Unfortunately, you have to dismantle a fair portion of the insides of the doors to remove the vent window frames and separate the glass frame from the weatherstrip retaining frame .
You'll have to at least move the division bar back a few inches, which means dropping the glass, remove the fuzzies, window run over the top and a few screws that hold it in place. Once it is moved away from the vent window then you can remove a couple of screws on the leading upper edge of the door and the vent window will be able to be removed.
If the paint on the truck is not something you'd want to damage I'd tape off around the opening some. Removing the fuzzies is tricky enough without damaging either them or the paint.
Old Dec 4, 2015 | 09:24 AM
James88f150/65f100
When you say divider bar do you mean the one between the vent window and roll down window? And where would I find a new pivot stud?
Old Dec 4, 2015 | 11:40 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes, the division bar is the vertical piece between rollup window and vent window.
The studs are not sold separately that I know of. I have seen a thread where a guy made his own. Here....
https://www.ford-trucks.com/forums/1...l#post14850373
Otherwise, they do make reproduction vent window frames or there are some NOS available last I checked. This link should take you to one possible offering. Most of the reproduction guys sell these, too. To a certain extent they are superior to NOS, even though I'm the last guy to admit something like that. They use a better designed stud with 3 rivets holding it to the frame instead of just two rivets.
Vent Window | Dennis Carpenter Ford Restoration Parts
Old Dec 12, 2015 | 02:30 PM
my 66's Avatar
my 66
can you weld
I mig welded my stud back in place. used spot welding. spot weld then cool it down, spot weld cool it down. I didn't take the glass out. put tape on glass so as not to damage it. after welded solid I took a die grinder and dressed it off. is working fine.
Old Dec 12, 2015 | 05:21 PM
daveengelson's Avatar
daveengelson
First and Foremost; Welcome to FTE. Decided to tag-on to this thread, not clear which item is being referred to? I have replaced the pivot arm; both at the vent window channel, and the pivot arm housing (not sure what it is referred to ) located on the vent window. Have a couple pic's of vent window disassembled and perhaps a spare pivot arm, or housing, depending upon left or right side??
Old Dec 12, 2015 | 08:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
21464 = Upper Vent Window Pivot Bracket
Old May 21, 2020 | 12:20 PM
wellcraft17's Avatar
wellcraft17
When I got my 56 back in the early 80s the frames looked gloss black and that’s what I painted them.
cander06
Apr 21, 2016 09:40 AM
DougofMontana
Jun 22, 2015 10:30 PM
Bertha1
May 20, 2013 10:48 PM
carnut122
Dec 11, 2010 07:47 PM
burlii
Aug 26, 2002 07:36 AM
