Electrical Problem
Old Nov 26, 2015 | 05:03 PM
reloaderbill's Avatar
reloaderbill
Electrical Problem
So since it's thanksgiving and auto parts store is not open, I have time to post a question and see what others may suggest. Yesterday was driving my 197 F250 7.3L diesel. Stopped to see a friend for five minutes. Returned to my truck and noticed my battery, ABS, and emergency brake light indicators were illuminated. Put the key in the ignition and turned it to on position. Key seemed to turn more easily than normal. The "wait to start" light did not come on, and truck did not turn over when I turned the key to the starting position. I checked all connections to starting solenoid, batteries, and fuses. Nothing out of place. Pulled cover off of steering column and found all connections seem to be connected. Pulled ignition and then put it back in.
To get the truck started, to get home, I used jumper cables and ran power directly from battery to starter solenoid. Ran fine. When I got, turned the key to off, but the truck would not turn off. Had to pull connectors from solenoid to get truck to shut off.
Any suggestion? Solenoid or possibly bad part within the ignition tumbler? Any suggestions help and Happy Thanksgiving.
Old Nov 26, 2015 | 05:14 PM
Phillip123's Avatar
Phillip123
Do yo have any clicking noise when you turn the key in the ignition or is it more a grinding noise? You might need to replace your starter.
Old Nov 26, 2015 | 05:25 PM
Hussler's Avatar
Hussler
Part of the problem is a bad GPR, shorted inside. When that happens 12 volts if fed back on one of the small wires to fuse #22 powering up the PCM. That accounts for the dash lights, no WTS light and not turning off. Seen it before.
Old Nov 26, 2015 | 07:31 PM
reloaderbill
Thanks, I will try that. It was only 6 years ago I replaced the GPR. I don't remember it being the same symptoms but it is a cheaper fix if that is truly the problem. Phillip123, there is no noise there is 1 click from up in the engine compartment when I turn the key.
Old Nov 26, 2015 | 09:35 PM
ReBilld's Avatar
ReBilld
X2^^^^^^^^ I have seen this also.
Old Nov 29, 2015 | 04:38 PM
reloaderbill
So I replaced the GPR and still the exact same problem. So I think that is ruled out. I've checked the electrical relays (all that I know exist), and I've pulled the ignition switch (tumbler housing) and there is nothing that sticks out as being broken. Can anyone think of anything else that might cause this issue?
Old Nov 29, 2015 | 05:10 PM
farmert's Avatar
farmert
My son had a 95 that did the same thing. On his a pin came out of the switch linkage assembly in the steering column.
Old Nov 30, 2015 | 11:01 AM
madpogue's Avatar
madpogue
This sounds more like the ignition switch / key cylinder than anything under the hood.
abranz
Nov 16, 2014 01:07 AM
unofornaio
19
Sep 21, 2014 06:14 PM
oarhead61
Apr 12, 2006 02:13 PM
dw1_hoosier
Aug 22, 2004 01:07 PM
OdinVII
Electrical Systems/Wiring
Jul 20, 2003 12:25 PM
