Romp question
Old Nov 17, 2015 | 07:05 PM
  #31
jed1894's Avatar
jed1894
Originally Posted by jhl3
The viscosity of the oil when cold is what helps or hinders the injectors. The "5" in the 5/40 is what makes all of the difference. Effectively, it is a 5w oil until it begins to warm up and it slowly becomes a 40W as it continues to reach FOT.
A "10" W would obviously bridge the gap, but it might be "close and yet no cigar".
I would try the 5/40 T6 for this winter at a minimum. You may find you'll run it all the time. The injectors in this 7.3 are noticeably quieter with the 5/40.
Yep. Been to walmart twice to get it but sold out both times. Stuff is popular
Old Nov 17, 2015 | 07:11 PM
  #32
jhl3's Avatar
jhl3
Same as here right now. It is seasonal. Every year I plan to stock up during the summer and then fail to do it. I just stop at every WM I see while traveling until I find it after I wait too long.
Old Nov 18, 2015 | 06:33 AM
  #33
Tugly's Avatar
Tugly
I'm a big fan of Mobile 1, and Delo is a nice product as well. Just look for the CJ-4 rating on the oil - there are many flavors. Rotella T6 is the bargain basement "synthetic".
DieselDenny - My Gawd man. I flash my tool and this is what you see?
Old Nov 18, 2015 | 02:09 PM
  #34
Oldguyfl's Avatar
Oldguyfl
T6 5-40 NO ROMPS
03 7.3
Old Nov 19, 2015 | 03:27 PM
  #35
rufushusky's Avatar
rufushusky
Originally Posted by jed1894
Looking around Shell site and saw this. All I ever saw in T5 was 10w30. Might be a good in between oil for some climates. Cheaper than T6. Anyone here ever use this or is it new?
After reading the specs on each oil, the T5 doesn't mention diesel motors at all. Says heavy duty but not diesel. The T6 mentions Diesel engines several times in the product description. Interesting
I have run T5 10w30 in my PSD, no issues at all. My truck started fine unassisted below zero which is about as cold as it will get around me. Really good bang for your buck oil IMHO.
T5 is CJ-4 rated, which means it is a diesel rated oil.
http://www.farleycompany.com/pdf/dat...-30_(CJ-4).pdf
bismic
Aug 22, 2019 03:32 PM
IABill
5.0L Coyote
Nov 30, 2015 01:11 PM
JayFan
30
Mar 6, 2015 10:00 AM
rebel33382
Oct 11, 2012 03:33 PM
ponch37300
Oct 18, 2006 09:45 PM
