Wiring questions
Old Nov 15, 2015 | 09:24 AM
MARC's Avatar
MARC
Wiring questions
Bought an EZ wire kit. When those of you that rewired their trucks, did you use you original light switch? Is the voltage drop only for the gauges on the dash, or is it also for the dash lights?
Thanks for your help
Marc
Old Nov 15, 2015 | 12:17 PM
hiball3985's Avatar
hiball3985
Should only be for the gauges.
Old Nov 16, 2015 | 01:26 AM
Tedster9's Avatar
Tedster9
I'd spring for an NOS light switch and floor dimmer switch. This will save headaches later on.
Old Nov 16, 2015 | 11:55 AM
montego69's Avatar
montego69
I rewired my 1960 F100 with a GM style, universal wire kit from Speedway. I then used the light switch provided in the kit and retrofitted the Ford **** to it. The kit allowed for the floor mounted dimmer. I also incorporated all new universal gauges and a headlight relay kit into the upgrade.
Nick in WI
thowle65
Feb 11, 2015 09:00 PM
vwfreak
Nov 6, 2013 06:21 PM
90pioneer
Apr 20, 2013 05:31 PM
1955effie
Sep 16, 2012 03:28 PM
Rust is too a color
Electrical Systems/Wiring
Feb 14, 2012 12:38 PM
