Tow capacity increase
Old Oct 31, 2015 | 08:02 AM
  #31
BruteFord's Avatar
BruteFord
If we're talking about the OP, good chance he has a LD F250 and thus a M5OD.
Even so this whole OD gear and towing thing is the same no matter the transmission. The reason not to tow heavy in OD has nothing to do with the actual ratio. The ratio is what it is, if it's the right ratio for the speed/RPM then so be it. What it's about is that 4th is direct drive, the input gear/shaft is connected directly to the main/output shaft. The gears carry no load in 4th, they just coast. This makes the transmission run cooler in 4th then it would in 5th. Is it really much of a problem, no not really, 99% of the time it's just fine. Just something to be aware of for that 1%.
Old Oct 31, 2015 | 08:39 AM
  #32
PlumCrazy7's Avatar
PlumCrazy7
Originally Posted by Diesel_Brad
I am pretty sure the engineers at ZF know more about oil than a trans repair shop
Maybe, but I suppose the actual big wigs there had no say in selecting Ford atf. There are more factors in production than good sense.
Old Oct 31, 2015 | 10:08 AM
  #33
Conanski's Avatar
Conanski
Originally Posted by PlumCrazy7
Pulling 5000 pounds that 302 is going to be worthless in the sub 2000rpm range,
The 5.0 is worthless below 2000rpm all of the time... but it has no problem turning 3000rpm all day long.
Old Oct 31, 2015 | 10:18 AM
  #34
PlumCrazy7's Avatar
PlumCrazy7
Agreed, but assuming he could maintain 3000 in 5th it will be way too fast when testing the limits of the truck. Not saying it can't pull it but I would avoid pulling in 5th with his truck.
Old Nov 1, 2015 | 07:15 AM
  #35
Diesel_Brad's Avatar
Diesel_Brad
No where in ZFs warranty paperwork(when you buy straight from one of there certified rebuilders) does it say to use FORD ATF. it says to use Mercon/Dextron in the gas ones and Synthetic in the diesel version. Same goes for the ZFs used in GM applications
gunit024
13
Jul 24, 2007 11:07 AM
hotarri
1978 - 1996 Big Bronco
Apr 2, 2005 08:08 PM
bremen242
All Things Towing
17
Jul 28, 2004 07:48 AM
JustinH
All Things Towing
Jun 11, 2004 09:05 AM
PSKSAM2
1983 - 2012 Ranger & B-Series
Oct 14, 2003 06:27 AM
