towing capacity is weak?
Old Jul 23, 2007 | 04:47 PM
gunit024's Avatar
gunit024
Question towing capacity is weak?
I bought a 1994 F150 2wd, 5spd, I6, for the purpose of towing my boat which weighs roughly 3500lbs with trailer. I just took a look at its towing capacity in the manual and it says my truck's towing capacity max's out at 3000lbs. How can a fullsize truck be that weak? Can someone recommend to me the minimum combination of truck I'd need to tow 3500lbs?
Old Jul 23, 2007 | 06:43 PM
Dean88's Avatar
Dean88
3000 lbs maximum? Huh I've had enough wait on my '87 that the frame was only a couple of inches above the axle (28 foot stock trailer, full of steers, and hay stacked on top of the trailer). The 300 will make childs play out of that 2 ton boat. Your only week link is probably going to be your bumper if your using that to pull, unless someone has installed an aftermarket bumper. I built me a bumper out of 1/2 plate so I knew that my bumper wouldn't ever get damaged.
Old Jul 23, 2007 | 07:02 PM
jroehl's Avatar
jroehl
For one, you probably have the Mazda 5-speed tranny, which is fine for a lightly-used truck, but probably not that great for lots of towing. Two, you didn't post your rear gears, but they could be a 3.08 setup, which also isn't good for towing, but is good for mileage.
In this case it really doesn't have anything to do with the frame, brakes or suspension, but the driveline behind the engine.
Jason
Old Jul 23, 2007 | 08:32 PM
Dustin1690's Avatar
Dustin1690
Yeah just to add they say you can tow more with the automatic dont know why
Old Jul 23, 2007 | 08:37 PM
jroehl's Avatar
jroehl
You can tow more with an automatic because the slippage in an auto (heavier load = more slippage) is entirely in the fluid in the torque converter, which means little wear. On a standard with a heavy load, there is more slippage on the clutch plates, resulting in much more wear. It also has to do with the torque multiplication that takes place in the auto tranny/torque converter.
Jason
Old Jul 23, 2007 | 08:42 PM
Dean88's Avatar
Dean88
Jason
With all do respect, I'm gonna disagree. The experiences I've had with autos, they always seemed to slip when I needed power most. And as far as wear, the when I replacaed the clutch in my '87 after 230,000 miles (most of those were pullin large loads) the clutch didn't have very much wear at all.
Old Jul 23, 2007 | 08:59 PM
jroehl's Avatar
jroehl
Your T18 is not a Mazda. As for the slippage, that's kind of a small factor. The torque multiplication of the auto is a bigger factor--there was a thread about the engineering and physics behind this quite some time ago (probably over a year or year and a half) in the general automotive or tranny forum. Personally, even though I have an auto, I would prefer a HD manual tranny when it comes to towing. I feel I have more control of the vehicle and trailer that way. The only time I have ever had an auto slip was when something was wrong (low fluid, smoked tranny, etc). I towed well over 6000 lbs. with my 302/AOD, even uphill, and it didn't slip. It didn't like it, but the tranny didn't slip.
Jason
Old Jul 23, 2007 | 10:04 PM
fordman1090's Avatar
fordman1090
Ford sets there max towing rate vary conservatively. These trucks will handle much more then you think. I tow a 5000 lbs. boat all the time and and the 300 doesn't even feel it. The mazda 5 speed on the other hand, its about to fail on me. Im pretty rough on it, but im hoping that if it does go ill get the zf 5.
jroehl "Your T18 is not a Mazda"
Are you talking about the original poster or dean?
If its the original poster and he has a 5 speed its either a mazda or the zf 5, and there are not many f150s with the zf.
And as for the t18, did they put the wide ratio t18a(first gear ratio= 6.32) or just the normal t18(first gear ration= 4.02) in the f 150s?
Old Jul 23, 2007 | 10:08 PM
pfogle's Avatar
pfogle
The mazda m5od will hold up just fine, you might need a clutch upgrade is all. The clutch is really the weak link here.
Old Jul 23, 2007 | 10:20 PM
jroehl's Avatar
jroehl
I saw in Dean88's sig that he has a T18...which I would say is much better than the Mazda 5-speed from what I've read here. The OP probably has a Mazda tranny, which is not known for its towing ability, but is known for good mileage.
Jason
Old Jul 23, 2007 | 11:18 PM
Dean88's Avatar
Dean88
Mine is the 6.32 version. I might be mistaken but I though all Ford T18's were 6.32. I know the Jeep T18 had several different first gears, and I if I remeber correctly the T19 had a first gear around 4.02 or something of sorts.
Old Jul 23, 2007 | 11:56 PM
fordman1090
Ok cool, thanks, the site that i get my trans info gives me both and i wasnt sure which ford used.
Ya if the t18 has the 6.32 then i would been tons better then the mazda. The mazda is originally a mini truck trans but they just lowered the gears. It will hold up to pulling, but not for long. Iv got 93k on mine and it is really sloppy.
pfogle- "you might need a clutch upgrade is all. The clutch is really the weak link here."
Im running the exact same setup and i have never had a problem with the clutch slipping under load. You could always upgrade to a clutch that will give you a smother grab and release and run cooler and last longer, but unless your running some crazy mods the stock clutch will be fine. And you probubly dont wanna pull the tranny unless you have to.
Hope im helping.
Good luck
Old Jul 24, 2007 | 08:51 AM
pfogle's Avatar
pfogle
My point is that the more miles there are on the truck the weaker the clutch is going to be. If it starts to slip it will smoke itself in short order while towing.
Old Jul 24, 2007 | 11:07 AM
GRAVEYARDSHIFT's Avatar
GRAVEYARDSHIFT
Swap the rear end for at least a 3:73 if you want to tow anything. It will wake it up and still cruise at 65. . Pat
mrwolf
Sep 26, 2024 04:53 AM
dcullen
Apr 29, 2020 08:45 PM
fishman24
Feb 4, 2020 09:19 PM
Ottawasteve
2015 - 2020 F150
Mar 20, 2015 10:28 AM
rosenkranswa
Sep 12, 2011 01:44 PM
