i believe the tow rating is 5-6,000lbs with the proper class 3 reciever. I wouldnt tow more then 1000lbs off the stock bumper. trailer brakes will help no matter what length the trailer/boat is but 25' is probably max
Check your axle ratio. If it's 3.55 and you have 31's, I wouldn't tow more than about 2,500 lb. if you have hills at all. The 302 doesn't like to lug. Far as I know, stock bumper is rated at 3,500 lb. but make sure. Also, see if you have tow package and add at least a tranny cooler if you don't.
I would not recommend a heavy load with the stock bumper either. I pulled some tree stumps out with mine and it caused it to sag. I had to get under neath and re-adjust the bolts. I have a class III hitch for it in my backyard. The only problem is that I need to drill bolt holes in my frame and I don't feel like getting into that project right now. Also, with the stock height of the truck I already drag my bumper when off-roading, the hitch would make it worse.
just a thought...if you ever do get around to mounting that hitch and need to drill holes in the frame...get one of those tapered/stepped drill bits that allow you to drill progressively larger holes as the bit goes into the material.
I bought the one that drills up to 3/4 inch hole - about $30 at Lowe's. I was drilling into some 3/16 inch steel square tubing and that bit handled it like butter (6 holes). Don't forget to use some WD40 or other oil every once in a while to keep the temp under control. Once you drill a pilot hole in the frame, this stepped bit works lots better than regular drill bits. The guys on Orange County Choppers use em' all the time - that's where I got the idea!
I had 4.10's installed in mine with 31's and its BETTER on gas and STAYS in OD going up good size hills when empty I really like the 4.10's
I pulled my car trailer yesterday about 17-1800lbs and it was loaded with 4000lbs of logs. I went over a scale and it was 7740 truck, us junk in the truck, and the trailer. with the logs it was 11700. It pulled pretty good but you really KNOW the weight is there....
With a class for hitch and dual tranny coolers and temp gauge I towed 6000 pound trailer from Riverside CA to Tallahassee Fl around June 23 of last summer down the I-10 through the freaking desert. The trailer is equipped with surge brakes. The Bronco is my daily driver. I did have it regeared from 3.55 to 4.1 before the trip. Thats with a 302/AOD. That's all I have to say about that.
Thanks, i will look into doing that down the road. I only tow aroung once a month or so right now, so I am not in that big of a hurry. I think when I lift it I will put it on.
I also have a 302 with 31in. tires and 4:10 gears. The new gearing made a huge difference with towing. When I rebuilt my AOD I also installed a Transgo reprograming kit. It shifts very firm, I like that when I am towing.
my 89, 302 is a gutless wonder with it's stock size 31 inch rubber!
Don't know it it's true or not - but a tranny guy told me to not use OD when towing much weight, as the lower RPM's won't allow the tranny's fluid to flow at a high enough rate to do a good job of keeping things cool...I don't even use OD around town, only at higher speeds of 45 & up...
He is right. It is hard on the overdrive band when you use O/D when towing something heavy or when going under 55. It will burn it up quick. I just keep mine in Drive when towing or around town.
