Diesel stalling?
Old Aug 4, 2003 | 06:29 PM
gforster's Avatar
gforster
Question Diesel stalling?
I replaced the cam sensor on my 95 350 psd and now a couple of weeks later it is stalling when I come to a stop and when putting it in reverse I noticed today that I can keep it from stalling by putting the trans in neutral (automatic). I have also noticed that ocassionally at idle the truck is rocking much more than usual. Any ideas?
Old Aug 18, 2004 | 12:07 AM
t-hanna's Avatar
t-hanna
I know you posted this a year ago, but the same exact thing is happening to me. Did you fix the problem? If so what was it?
Old Aug 18, 2004 | 12:09 AM
Kwikkordead's Avatar
Kwikkordead
He probably had to pull his 10k mod out of the truck.
Old Aug 18, 2004 | 12:13 AM
t-hanna's Avatar
t-hanna
What is that?
Old Aug 18, 2004 | 12:32 AM
t-hanna's Avatar
t-hanna
I don't have that mod on mine.
Old Aug 18, 2004 | 04:02 AM
Technitom's Avatar
Technitom
Veteran: Navy
poor fuel? dirty fuel filter? clogged injector(s)? maybe try changing the fuel filter, and fill the filter bowl up with stanadyne before putting on the cap in order to flush the injectors, start and let idle for 10-15 minutes (DO NOT DRIVE OR REV MOTOR) just let it idle
the only other thing can think of off the top of my head is possibly corroded or burnt contacts on the wiring harnesses to the injectors. without more info it is hard to guess....
btw/ the 10K mod is a 10k ohm resistor wired into 2 pins on the ICP, what it does is fools the computer and make it increase the fuel pressure on the fuel rail supplying the injectors. Its pushes in a little more fuel and gives a little more pep... but it can also cause your truck to idle rougher
Old Aug 18, 2004 | 07:19 AM
blackf3504dr's Avatar
blackf3504dr
Technitom , You stated the 10K mod will make the truck rough . I have had my truck a little over a month ,and it also idles rough , how would I check to see if this mod has been preformed ? If this isn't the cause of the rough idle , any ideas ?
Old Aug 18, 2004 | 09:32 AM
Kwikkordead
Check my gallery for a picture of a 10k.
Old Aug 18, 2004 | 05:22 PM
blackf3504dr
Thanks Kwikk' .
davidmolina
Jul 30, 2014 10:19 PM
RKCORPS25
Apr 1, 2014 11:21 PM
gildardo01
Feb 1, 2013 11:40 AM
900rr
Dec 22, 2006 06:50 PM
jsphsol6
Nov 13, 2006 04:16 PM
