stalls in reverse
Old Nov 13, 2006 | 08:20 AM
jsphsol6's Avatar
jsphsol6
stalls in reverse
i just bought a 97 f350 reg cab 7.3l diesel. when i put truck in reverse, it stalls out. start it back up and goes into reverse without stalling. 138k miles on motor.
Old Nov 13, 2006 | 08:32 AM
Cuda_jim's Avatar
Cuda_jim
Do the Obvious stuff first. Check fluid level (hot). Does it smell burnt or is it dark (not blood red). Change the fluid and filter if you see something out of spec. Since the truck is new to you I suggest doing this anyway even if you find the source of your trouble.
Check all electrical connectors on the tranny. Pull them and inspect terminals (both ends).
Do you have any lights flashing or lit?
Most tranny shops will scan it for free. It could be something that doesn't trigger a light to come on.
Old Nov 13, 2006 | 09:55 AM
DAN-D-DIESEL97's Avatar
DAN-D-DIESEL97
maybe in the torque converter? mine did this on occasion until my trans took a dump.almost felt like the converter was in lock.just an idea
Old Nov 13, 2006 | 10:22 AM
DaBigTow's Avatar
DaBigTow
Mine will lug in reverse if I leave the EBPV exhaust brake activated. Flip it off & I instantly gain almost 100prm. Hasn't died, though. I vote for torque converter.
Old Nov 13, 2006 | 04:13 PM
Briansshop's Avatar
Briansshop
Low line press. can cause the t/c clutch to grab in reverse.
Brian
Old Nov 13, 2006 | 04:16 PM
catalinagoose's Avatar
catalinagoose
Sometimes the trans pickup screen/filter will fall off and cause stalling into reverse. Check and see if it's laying in the bottom of the trans pan.
josephk12
Jul 25, 2015 08:39 PM
ml_nelson
Oct 28, 2013 08:12 AM
TexasGuy001
16
Feb 8, 2012 03:39 PM
billf250
May 23, 2011 10:42 PM
tbart16
Feb 1, 2010 11:31 AM
