Sponsored by: Real Truck
stalls when put in reverse
Old Dec 19, 2006 | 06:37 PM
900rr's Avatar
900rr
I just bought a 2000 v10 super duty and when put in reverse and you are turning the wheel it stalls out! It only stall out while turning the wheel the engine idles up some then will drop to about 600 rpm and only stall when turning the wheel .any help would be great!!!!!!!!!
Old Dec 19, 2006 | 06:44 PM
DD1684's Avatar
DD1684
I was thinking possibly throttle position sensor, but I'm not so sure it would cause that to happen.
Old Dec 20, 2006 | 09:38 AM
RideRed05's Avatar
RideRed05
sounds to me like your torque converter is cuasing the problem. Your idle should not drop to 600 r's when shifting and the resistance of the power steering just pulls the rpms down even more til it dies
Old Dec 20, 2006 | 10:21 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is it doing it going forward?
Old Dec 20, 2006 | 01:19 PM
900rr's Avatar
900rr
No it does not seem to do it in drive!!! It has not been fun with this truck just bought it on the 8th at a ford dealer and it is the 20th and i have had it 2 days to drive ever thing seems to be wrong with this truck!!!!!!!I am asking for my money back real soon stalling is not the only problem with this truck.......
Old Dec 20, 2006 | 02:40 PM
biz4two's Avatar
biz4two
Arrow
I suspect the power steering pump. It might just need a GOOD flushing and refill.
TEST (if using OEM size tires):
1. Check your front tire pressure...and record.
2. If at 55psi or below...add until 70psi.
3. Now at 70psi...try backing up and turning. Does the V10 still stall?
If NO, then your power steering needs a flush or replacement. Reason being is that when your front tires are at a lower psi that causes more drag or resistance...and makes your power steering work harder.
Good luck...
biz
Old Dec 20, 2006 | 02:49 PM
900rr's Avatar
900rr
Dealer ship just replaced power steering pump and fluid and the problem is still there . The pump was replaced because when you are sitting still you can not turn the wheel after replacing the problem is stll there and the wheel will not turn!!!!!
Old Dec 20, 2006 | 03:25 PM
TwelveAlpha's Avatar
TwelveAlpha
Long shot, but how's your tranny fluid smell, and do you have a gauge for temps?
I'll qualify that - I had a kinked tranny line once briefly (right after work had been done on it) and the resultant pressure for whatever reason made the truck stall out when I went into reverse. That's my contribution to stabbing in the dark :-)
Old Dec 20, 2006 | 03:45 PM
900rr's Avatar
900rr
I just had the tranny flushed when i bought it for precaution so i have no idea. dealer also just called and said that it was the iac and they replaced the pcm.
Old Dec 20, 2006 | 03:54 PM
biz4two's Avatar
biz4two
Arrow
Thanks for posting back. Hope the IAC and PCM correct the issues. Looks like your dealer is working hard for you...
FYI...you can look in my gallery and I have a step-by-step of the IAC removal and install. If you are curious...
biz
Old Dec 20, 2006 | 04:49 PM
redford's Avatar
redford
OK, I was going to sugest IAC as a possibility. Let us know if that solves the issue!
Old Dec 22, 2006 | 06:50 PM
900rr's Avatar
900rr
Just posting about repair after the iac and pcm fix the problem seems to be gone. Also i was wondering when you take the oil filler cap off there is the white milky residue on the cap the oil looks fine but i am a little worried about the head gasket the truck has been sitting and in and out of the shop in new york so it is colder out side have not had it long enough to see if it is losing anti freeze yet but any help would be great . also how do you check for the head gasket if it was a problem?
Radconpro
13
Feb 7, 2020 06:18 PM
GodsHammer
Apr 19, 2017 10:06 PM
Trevor253
1983 - 2012 Ranger & B-Series
May 27, 2016 12:25 PM
billf250
May 23, 2011 10:42 PM
900rr
Modular V10 (6.8l)
13
Jan 21, 2007 10:01 AM
