would it fit?
Old Oct 12, 2015 | 05:20 PM
69issofine's Avatar
69issofine
would it fit?
i have a 69 f250 cs with a c6 tranny out of a car would a e4od bolt up behind my 390. the c6 is messed up linkage won't line up,goes to far into park and can't get it out. it was towed out of a field in park and that didn't help.
Old Oct 12, 2015 | 06:54 PM
85e150's Avatar
85e150
E4OD will not bolt up without an expensive ($800+) adapter, plus a $500+ controller.
C6s are cheap to fiddle with, stay with it on your other thread.
Old Oct 13, 2015 | 02:21 AM
stuart1's Avatar
stuart1
You need the proper shift arm from a truck. There are umpteen different arms. The park rod is probably jammed inside. The valve body will have to be removed.
Old Oct 13, 2015 | 12:03 PM
69issofine's Avatar
69issofine
that is what i thought.
BobnSofi
Jun 21, 2011 12:20 PM
cpt-petro
Jun 28, 2009 08:17 PM
zswiss182
21
Apr 14, 2009 10:17 PM
DW2455
1978 - 1996 Big Bronco
May 3, 2004 01:04 AM
78CREW
May 22, 2002 01:36 PM
