70 c6 problem
Old Oct 12, 2015 | 05:46 PM
69issofine's Avatar
69issofine
70 c6 problem
i have a 69 f-250 cs the tranny went out so i went to the wrecking yard to get another tranny. everything bolted up just fine except the shift linkage it was to short. so i set the truck aside thinking i would get back to it when i had time,but life caught up with me,got a divorce,she got most everything,except the truck ,but i had to move it in a hurry. so my neighbor hooked on to it and pulled it down a dirt road in park.is there a difference between a car c6 and a truck c6? when i got the last one it was sitting out in the yard and the guy said it didn't matter they are all the same.he has since went out of business. next time i will take it out of a truck and buy a new torque converter and front seal. is there any way to check it to see if it is good before i kill myself putting it in by myself? any help would be appriciated thanks.
Old Oct 12, 2015 | 06:52 PM
85e150's Avatar
85e150
Car C6: Shift arm points up.
Truck C6: Shift arm points down.
Your shift quadrant will be reversed--P will be 1st, 1st will be Park.
Gotta pull the pan and fiddle with it to fix. Shaft comes out, but fitting on the end might be different.
There is a recent thread on this, I will see if I can spot it and post a link.
Old Oct 12, 2015 | 07:00 PM
85e150's Avatar
85e150
This is the one. He talks about the shift shaft with pics a few entries into it:
https://www.ford-trucks.com/forums/1...backwards.html
Old Oct 13, 2015 | 12:08 PM
69issofine's Avatar
69issofine
so i must have one from a car and all i need to do is switch he shift lever around?
Old Oct 13, 2015 | 12:13 PM
69issofine's Avatar
69issofine
the shift quadrent being backward makes sense now just need to tinker some more with the electrical.i loaned the truck to a friend and he didn't return it for a few years. came back with a floor shift and messed up wiring and broken valve cover bolts.
dreamofford
Jan 19, 2018 01:21 PM
EWHOLTZCLAW
Apr 5, 2013 06:21 PM
71BlueBoy
Nov 27, 2012 09:16 AM
turbosek2
Jul 20, 2003 05:18 PM
airharley
Jun 15, 2003 07:44 PM
