Fuel line size
Old Oct 6, 2015 | 02:24 PM
vettman's Avatar
vettman
Fuel line size
I need to replace the rubber fuel lines leading to and from the fuel pump on my 1976 F350 with 460. Because of crud, etc. I can't confirm if they're both the same size or not. FYI, this is the fuel pump with the screw on canister type filter. I'm thinking they both might be 3/8-inch but want to check with some of you pros before I hit the local NAPA.
Thanks
Old Oct 6, 2015 | 07:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
From the tank to the pump is 3/8", from the pump to the carb is 5/16"
Old Oct 6, 2015 | 08:39 PM
vettman's Avatar
vettman
Thanks
I gambled that it was 3/8ths, so went ahead and bought a couple of feet while I was out earlier this evening. I thought the short piece to the carb was smaller so went ahead and got a foot of 5/16ths. The clerk gave me that piece after he discovered someone had partially cut it about an inch from the starting end. It still left me much more than I will need.
Mikey G
Aug 12, 2016 10:00 PM
'78F250351m
Sep 16, 2011 05:17 AM
nlareau
Aug 1, 2011 08:57 AM
boaterbob
Dec 4, 2010 06:39 PM
himmelberg
Jan 25, 2004 02:37 PM
