Fuel line blues
Old Jan 24, 2004 | 10:54 AM
himmelberg's Avatar
himmelberg
Fuel line blues
Recently swapped out carb and fuel pump. Enormous frustration has set in... all I want to do is to replumb from pump to carb. Ultimately, I will get the 3 deuces set up (when I get my carb base from Vintage Speed). Questions:
1. What tube size do I need for this application? I have 5/16ths right now.
2. What size and where might I get fittings for the pressure regulator.... It necks down to 1/4".
3. Where do I locate my fuel line filter a), b) or somewhere else?
None of my local parts places will even sell me brake line. Will have to go to NAPA in Odessa, I guess.
Can't believe such a simple thing is giving me so much grief. Thanks. himmelberg
Old Jan 25, 2004 | 12:23 PM
Midnite Cruiser's Avatar
Midnite Cruiser
I feeeel your pain.
As with any plumbing project, its best to get to a very good supplier (the NAPA house near me that keeps the dirt trackers happy had drawers full of fittings , couplings etc) . Take the parts that represent your problem with you and find a counter man to spend quality time with. Measure the length of the tubing runs (5/16 sounds fine) so cutting and flaring can be done at that shop- you can do the bending when you get home.
I put my fuel filter above (past) the fuel pump so I could see fuel delivery, but pre-pump should be fine
Old Jan 25, 2004 | 02:37 PM
286merc's Avatar
286merc
Too cold to go out and measure mine! But 5/16 sounds good. Put a filter before and after the pump, your pump and carbs will thank you.
himmelberg
Aug 7, 2008 06:03 PM
66gpw
32
May 15, 2007 10:55 AM
red's 78camper
Nov 15, 2004 07:30 AM
himmelberg
Oct 20, 2004 07:11 PM
himmelberg
Feb 8, 2003 09:04 AM
