Security
Old Oct 6, 2015 | 10:35 AM
devovino's Avatar
devovino
Security
I was wondering,since my Ex has this 6 position chip which in turn makes the "SECURITY" light blink constantly for the first couple minutes upon start up, then eventually stops, does this have any effect on the actual security system itself? How am I to know that the PATS I believe its called is still functioning? Reason being I am driving my Ex to the airport tomorrow morning for a vacation, and will be leaving it for a week or so, then it got my mind spinning about the potential to come home to an empty spot where the Ex was.... not a good thought!
I do know that without the key, the Ex wont start because the chip in the key, is this correct?
Thanks
Devon
Old Oct 6, 2015 | 01:00 PM
Pele's Avatar
Pele
Take your key to the hardware store and have them make a copy... If they say your key is chipped, tell them you want the cheap $2.99 key just to have a spare to open the doors.
Try and start the engine with it.
If the PATS system doesn't read the right key, the "Theft" light will blink at you fast and the engine will just crank.
If the engine starts, PATS has been disabled.
Old Oct 6, 2015 | 01:05 PM
devovino's Avatar
devovino
That makes sense, I will try to give it a go. How does the PATS get disabled,is that a function of adding the chip or something separate?
I have thought about possibly removing a fuse to make sure it cant start while sitting at the airport, I guess that is an option, just have to remove the right fuse?
Old Oct 6, 2015 | 02:20 PM
devovino's Avatar
devovino
NO PATS
Well I had a key burned same as my "chipped" key, which it is in fact does have a chip, and much to my chagrin, it started up the Ex w/o any hesitation....damn!
I tried turning the 6 position all the way to the left to "off" but it still started the rig, makes me feel a little less "safe" about leaving my rig at the airport for a week, now what.... pull a starter fuse to make me feel a little less uneasy?
Old Oct 6, 2015 | 03:24 PM
JuanHuevos's Avatar
JuanHuevos
Isn't there a fuse for the IDM? You could pull that if so.
Old Oct 6, 2015 | 04:02 PM
devovino's Avatar
devovino
Truthfully, not even sure what the IDM is, ahaha?! But, I sure hope there is a fuse for it....
Old Oct 6, 2015 | 06:02 PM
Pele's Avatar
Pele
IDM is the Injector Drive Module. It's what runs the injectors on the Diesel engines.
Old Oct 6, 2015 | 06:07 PM
devovino's Avatar
devovino
Copy that, I am looking to see if there is a fuse that individually controls the fuel pump as I saw suggested somewhere..? Might do well, but also as I have seen before, if some body REALLY wants it, they will get it .... just peace of mind for me I guess. A little bummed that the PATS is not functioning however.
Old Oct 6, 2015 | 06:47 PM
Stewart_H's Avatar
Stewart_H
When you say you had them "burn" it, do you mean they programmed it? If so, then of course it will start the truck.
Pele was telling you to get a key cut (and only cut, not programmed) that will turn the ignition. Then check to see if the unprogrammed cut key will start the truck.
Make sure you leave your regular keys in the house when you try this method to see if your PATS has been disabled.
Stewart
Old Oct 6, 2015 | 07:43 PM
devovino's Avatar
devovino
[QUOTE=Stewart_H;15697384]When you say you had them "burn" it, do you mean they programmed it? If so, then of course it will start the truck.
Stewart[/QUIT
Yeah sorry, probably not the best verbiage, by "burn" a key I meant yes they "cut" a key, just a simple metal key unprogramed door key without a chip, and yes I left the original PATS key in my desk, snd the EXCURSION still started. ..
Old Oct 6, 2015 | 07:50 PM
Stewart_H's Avatar
Stewart_H
Ah, ok, gotcha!
Check out this thread: Truck stolen, got it back, how to prevent theft? UPDATE
PS - I'm assuming you have a 7.3L PSD since you refer to a 6 position chip. In order for us not to assume, you should fill out your signature!
Stewart
Old Oct 7, 2015 | 01:47 AM
JuanHuevos's Avatar
JuanHuevos
Originally Posted by Stewart_H
Ah, ok, gotcha!
Stewart
Darn it Stewart, I can't rep you for this assist either! That relay is what I was thinking of.
Old Oct 7, 2015 | 01:59 AM
devovino's Avatar
devovino
I thought I did update my signature at one point, maybe I updated something else. Yup, 7.3, I ASSume people knew what my ex is. ... newby stuff. Either way, I well look into the relay, for the time being, anybody knew of a fuse I can pull to temporarily disable starting, I looked through the fuse box schematics and nothing really fit the bill. ..?
Old Oct 7, 2015 | 04:43 AM
Stewart_H's Avatar
Stewart_H
Huh? Did you click the link I provided? Your answer is right there, with several different options given. I mean, I didn't type my post in invisible font, did I?
Stewart
mike71800b
26
Jan 23, 2019 11:52 AM
Fastback460
Dec 21, 2013 04:26 PM
jayram75
Feb 18, 2009 11:11 AM
Joel Steven
Oct 9, 2006 10:30 AM
Black88GT
Mar 2, 2005 09:18 PM
