P0405 code
Old Sep 30, 2015 | 11:03 AM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
P0405 code
This morning when attempting a cold start of my 05 6.0, it would not start was noticeably harder cranking. I had no CEL. I checked my scan Guage and the volts were 13.4 and fcm main power was 48.4. I checked and I had a p0405 code. Can anyone help me out as to what could be going on? I read that it can be a stuck or bad EGR valve? Any help would be appreciated. Could it be battery related? Thanks
Old Sep 30, 2015 | 04:33 PM
WatsonR's Avatar
WatsonR
That code is,an EGR code. Check the connector, the wire and pull the valve and clean it. Clear the code and see what happens.
Old Sep 30, 2015 | 06:36 PM
cheezit's Avatar
cheezit
Its an internal falt in the solenoid portion of the egr valve.
Old Sep 30, 2015 | 08:03 PM
WatsonR's Avatar
WatsonR
Means it's toast
Old Oct 2, 2015 | 10:00 AM
Stroker 6.0 fan
UPDATE. Noticed Batts were not up tonpar. Changed them out with new ones. The code has since reset.
Old Oct 2, 2015 | 11:10 AM
WatsonR's Avatar
WatsonR
the batteries have nothing to do with EGR internal fault... you probably have a bad sensor.
I'd also check the alternator output since the batteries went... normally its from a bad alternator. be fast about it, low voltage from batteries and alternator will kill the FICM.
Old Oct 2, 2015 | 07:56 PM
npccpartsman's Avatar
npccpartsman
And your codes reset because you changed out the batteries. As Randy said, they have nothing to do with the EGR internal fault code. It will reappear.
Old Oct 2, 2015 | 08:30 PM
Stroker 6.0 fan
What is the easiest or best way to test the alternator? My scan Guage is showing my volts at 13.5?
Old Oct 2, 2015 | 09:44 PM
cheezit's Avatar
cheezit
Ok who's Randy.
Test the alternator by removing it and go to autozone and bench test it.
Still wont fix a p0405 though.
Old Oct 3, 2015 | 03:07 AM
npccpartsman
Ok who's Randy.
WatsonR is Randy. I thought your name was "Chopped Liver"
billneal
1997 - 2003 F150
19
Oct 22, 2024 10:31 AM
scrobbie
Jan 27, 2014 07:10 PM
95F250man
Jun 24, 2004 04:44 PM
daw1264
1997 - 2003 F150
Feb 7, 2002 07:30 PM
