Sponsored by: Auxito
Code 401 EGR Flow Insuf Problem, Please Help
Old Jan 28, 2002 | 11:05 AM
daw1264's Avatar
daw1264
1997 F150 4.9L
I have a check engine light with code P0401 (EGR Flow Insuf). I replaced the EGR valve (the intake was clear) and cleared the code.
The same code returned after about 20 minutes of driving. The truck does not appear to run different code or no code.
Is there a valve/soleniod the controls the vacuum to the EGR valve and how would I check/test it.
Old Feb 5, 2002 | 01:15 PM
fixer1's Avatar
fixer1
I pulled the plenum from the manifold and found both ports totaly full of carbon. drilled it out, cured the problem. ws
Old Feb 7, 2002 | 11:11 AM
Deebo's Avatar
Deebo
Old Feb 7, 2002 | 07:30 PM
Bellevueauto's Avatar
Bellevueauto
start with the dpfe sensor, you will find that your local ford dealer stocks a lot of them....
