Sponsored by: Auxito
ERG replacement=code P0402
Old Jul 22, 2013 | 03:43 PM
billneal's Avatar
billneal
Last week my service engine light came on. Friend checked it with his code reader. Got a P0402 code insufficient flow EGR valve. I have read several different threads on this subject on another Ford truck forum, slightly confusing me. Should I trust the code and just replace the EGR valve or do a number of other things that I have listed below that have been suggested by others on the another forum.
1. Clean the throttle body first?
2. Test the EGR valve by blanking it off?
3. Test the DPFE valve?
4. Replace the DPFE valve instead of the ERG valve since the EGR valve rarely goes bad?
5. Only get OEM parts since after market parts do not last?
I plan on diving in on this problem on Thursday so some good guidance would be greatly appreciated.
Old Jul 22, 2013 | 08:29 PM
projectSHO89's Avatar
projectSHO89
Go look up the code definition again...
Old Jul 23, 2013 | 05:34 PM
billneal's Avatar
billneal
OK messed with it some yesterday evening, pulled both the egr and dfpe, tried to do some cleaning, really didn't have the right things needed, put it all back together, disconnected the battery, it cleared the code. Did OK until driving home this afternoon, ses light came back on. I will have my friend scan again and make sure I get the correct explanation for the code, sure the code was P)402, not sure about the explanation though.
Doing more reading in places and seems most say dfpe replacement is usually the fix. I am going to do some testing and better cleaning on both but at independently and at separate times to hopefully confirm my thoughts that the dfpe is the one to replace.
Always open for suggestions.
Old Jul 24, 2013 | 03:29 PM
billneal's Avatar
billneal
OK...my bad....I had the fault explanation right......insufficient flow detected......gave the wrong code ...it was PO401. I think I will clean the DPFE again and clear the code only to see in a short time the SES light return to affirm to replace the PDFE first, hoping that will correct the whole issue.
Old Jul 24, 2013 | 03:32 PM
billneal's Avatar
billneal
Looked online on the ford parts site and found two dpfe sensors listed for a 4.2 f150. One was 58 bucks, the other 108 bucks.
Has anyone ever substituted the dpfe sensors, put on the plastic one in place of the metal aluminum one?
Did some calling around about parts. I was told the difference between the two was the metal one ($108), which I have, was originally put on the 1999 f150 and half way through the production year they replaced it with the plastic one($58).
What is the difference other than material? Can they be interchangable? One dealer did not even carry the metal one and never heard of it. They only have the plastic one.
Old Jul 24, 2013 | 06:19 PM
billneal's Avatar
billneal
OK thought tonight I would do some work and try to see why I was able to have the ses light go off but for only a day so I was going to do a process of elimination on some cleaning. Figured I would start with the easier access of the 2 components to take off and that was the dpfe. took it off did some cleaning as best I could put it back on, disconnected the battery and reconnected and started the truck, low and behold the ses light was off. so I am thinking more and more that is the part I will be replacing. I am going to drive it until the warning appears again and then take it to advance to let them put their scanner on it to get the volts reading from the dpfe. this could also confirm the problem part. was going to do a seafoam cleaning but could not find an easy place to pour the chemical so that it might make it to the dpfe or erg so decided against messing with it, especially after cleaning the dpfe and the light going off.
Any input on the 2 different dpfe parts would be appreciated.
Old Jul 24, 2013 | 08:34 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/1...g-mistake.html
Old Jul 25, 2013 | 12:28 AM
Bluegrass 7's Avatar
Bluegrass 7
For information, it takes two drive cycles before the EGR system failure twice in sucession will set a code for 401 so you may still have an issue.
Adding any cleaner will never get to the DPFE or EGR because they are in an area outside the motor not accessed from inside the motor.
You already have worked on those areas and can see there would be no access by any cleaner.
The DPFE is connected to the exhaust system as is the EGR.
The flow is into the engine by exhaust pressure and intake vacuum so neither will benefit.
Good luck.
Old Jul 25, 2013 | 07:38 AM
billneal's Avatar
billneal
Bluegrass, I know the cleanings won't fix the problem. I was hoping by cleaning the parts would help me figure what part to replace by process of elimination.
Do you know if the plastic DPFE is interchangeable with the metal one on my truck?
Old Jul 25, 2013 | 10:12 AM
Bluegrass 7
Yes but use only the plastic type.
Good luck.
Old Jul 25, 2013 | 12:15 PM
RebColonel's Avatar
RebColonel
My 99 4.6 did exactly the same thing as yours. First do this hook a piece of hose to the EGR valve and with the truck running pull a vacuum on it, if you don't have a vacuum tester simply suck on the hose and the engine should stumble. If it does the EGR valve is good and that part of the EGR system is clean if not, pull off the throttle body and pull off the part that the valve attaches to and clean the crud out of it. If you have a metal dpfe sensor go ahead and replace with the plastic one.
Old Jul 25, 2013 | 08:28 PM
Schiz's Avatar
Schiz
I believe your light is going off, because the PCM resets the codes when the battery cable is off for more than ~10 minutes. I replaced my DPFE with the plastic one, with no change at all. I've also read that using ones that aren't Motorcraft will throw codes, so I guess I will see. The one I got was standardized for OEM, so I'm hoping it will work lol.
Old Jul 27, 2013 | 12:29 AM
Analogue's Avatar
Analogue
Did any symptoms coincide with the SES?
Check out this link.
Part 1 -How to Test the Ford EGR Valve and DPFE Sensor.
You will need a little multi meter found here....
Digital Multimeter - 7 Function, w/ Backlight
Old Jul 29, 2013 | 09:55 PM
artfd's Avatar
artfd
Exclamation
--- Only use the official Ford DPFE unit. There have been many comments on FTE about aftermarket DPFE's not working out correctly.
--- You've done lot of things, but you haven't reported the basic EGR valve test, which was already mentioned a couple of posts back. This must be done first when evaluating a P0401 code & has nothing to do with cleaning anything, or disconnecting the battery. Whenever you disconnect the battery you reset your code status anyway, regardless of what else you do.
--- I looked at this: Part 1 -How to Test the Ford EGR Valve and DPFE Sensor., and disagree with this part:
Common Symptoms of a BAD EGR Valve
The following are the most common symptoms that a Ford (or Mercury or Lincoln) car or truck will usually experience when there's a fault in the EGR System:
Car or truck runs fine, but the Check Engine Light (CEL) is on with an EGR Valve Fault Code:
P0401 EGR System Flow Insufficient.
P01406 EGR Valve Pintle Position.
Rough Idle.
Really BAD gas mileage.
Lack of power as you accelerate the vehicle down the road.
Car (or Truck or Mini-van) seems to run ok above 30 miles and hour but once you come to an idle, the engine barely stays running and/or idles rough. Once you take off again, it runs OK.
When my EGR valve went bad, I got a P0401 code, but had absolutely no other problems (outside of not being able to pass my state's emissions test). I wasted a lot of time & money cleaning & replacing things that didn't need it, when the only thing necessary was to replace my EGR valve, which was almost as easy as replacing a DPFE. The EGR valve was way cheaper than the DPFE, too.
Old Oct 17, 2024 | 10:14 AM
VincentThomas's Avatar
VincentThomas
1st Gear
1999 E350 5.4 Triton EGR 0401
My van is running perfectly but I have the 0401 code. I have replaced the EGR valve and the DPFE and related hoses that go to the DPFE. I am still getting the code. I used Motorcraft for the DPFE but O’Reilly’s for the EGR. Any tips anyone can give me would be welcome. I am late to register because I have to pass smog where I am in order to register. Also, my concern is it is something bigger/more expensive. What is the worst case scenario? Thanks!
