Code 33
Old Jun 22, 2004 | 02:57 PM
95F250man's Avatar
95F250man
Code 33
I ran the self test and got code 33. I tested the sensor on the egr valve and ended up replacing the EGR valve and the sensor on top of the EGR valve. Ran the self test agian and still get code 33. What do I do?
Old Jun 22, 2004 | 03:23 PM
jbjb5081's Avatar
jbjb5081
Did you disconnect your negitive battery cable for awhile ??To reset the codes or there is a few more parts that could cause that code.
Old Jun 22, 2004 | 03:28 PM
first time 4x4's Avatar
first time 4x4
Check the vaccum line going to it. If it is bad it can cause a code 33.
Old Jun 22, 2004 | 03:44 PM
95F250man's Avatar
95F250man
I disconnected the negitive term. for around 10-15 min. And still got code 33.
Old Jun 22, 2004 | 05:44 PM
EPNCSU2006's Avatar
EPNCSU2006
Check the EVR (mounted near the ignition coil) to see if it will hold a vacuum when it is closed. If it leaks vacuum, the EGR valve will open up when the computer is not expecting it to, and will throw a code.
Old Jun 22, 2004 | 08:24 PM
thomadm's Avatar
thomadm
Had the same problem with a 90 f-150, replaced EVR and it fixed the problem. There is a procedure using a voltage multimeter to check it. Good luck
Old Jun 23, 2004 | 06:18 AM
95F250man's Avatar
95F250man
All Fixed......Thanks for the advice. I finally got a hold of a freind and he told me it had to be reset with a computer. So I brought it to him......all fixed.
Old Jun 24, 2004 | 02:23 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Disconnecting the battery cable for 15 minutes should have reset anything that needed to be reset. Can you find out what was actually done?
Old Jun 24, 2004 | 05:48 AM
95F250man's Avatar
95F250man
I will try to get a hold of him to see what it is called that he did.
Old Jun 24, 2004 | 04:44 PM
HardScrabble
Thanks, I would like to know. I have heard of computer settings on GMs that are modified and then next time you disconnect your battery, you lose the setting and it has to be set again. This doesn't fix anything it just keeps from setting and error code and the check engine light. If he did something like that you should know what to expect.
On the other hand, maybe clearing the codes just didn't take when you disconnected your battery cable.
