Sponsored by: Real Truck
throttle cable
Old Sep 28, 2015 | 11:50 PM
DB9787's Avatar
DB9787
throttle cable
Hi, I have a 2003 f250 SD /w a 5.4 gas engine. The throttle pedal seem's to stick when you start off, you really have to mash on it and then it kind of clicks and then takes off, causing the truck to lunge forward. I think it's the throttle cable sticking. I have lubed the pedal it's self, that didn't help. Have any of you had this problem before? How do you lube the cable? Do you lube it from both ends and what kind of lube?
Thanks for reading! Dempsey
Old Sep 29, 2015 | 06:59 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Don't lube the cable. If the cable were sticking it would stick at any position. You problem is in the throttle body.
Tbug05LTD
Modular V10 (6.8l)
May 12, 2019 12:40 AM
hillbillyboy_316
Jan 17, 2019 09:25 AM
monkey jason
Feb 9, 2014 01:55 PM
BFTUFF
1997 - 2003 F150
May 22, 2012 02:05 AM
cbeaur
Nov 13, 2003 03:32 PM
